Aller au contenu principal
G-Wolves Hati Paracord Replacement
Ce dont vous avez besoin
  1. G-Wolves Hati Paracord Replacement, Mouse Paracord: étape 1, image 1 de 1
    • Flip your mouse upside down.
  2. G-Wolves Hati Paracord Replacement: étape 2, image 1 de 3 G-Wolves Hati Paracord Replacement: étape 2, image 2 de 3 G-Wolves Hati Paracord Replacement: étape 2, image 3 de 3
    • Peel off the back right mouse skate.
    • Peel slowly, you don't want to create bends on your skate.
  3. G-Wolves Hati Paracord Replacement: étape 3, image 1 de 3 G-Wolves Hati Paracord Replacement: étape 3, image 2 de 3 G-Wolves Hati Paracord Replacement: étape 3, image 3 de 3
    • Peel off the back left mouse skate.
  4. G-Wolves Hati Paracord Replacement: étape 4, image 1 de 3 G-Wolves Hati Paracord Replacement: étape 4, image 2 de 3 G-Wolves Hati Paracord Replacement: étape 4, image 3 de 3
    • Unscrew both of the uncovered screws.
    • 6.4mm Phillips-head screws.
  5. G-Wolves Hati Paracord Replacement: étape 5, image 1 de 2 G-Wolves Hati Paracord Replacement: étape 5, image 2 de 2
    • Squeeze the mouse under second mouse button until the bottom opens.
  6. G-Wolves Hati Paracord Replacement: étape 6, image 1 de 2 G-Wolves Hati Paracord Replacement: étape 6, image 2 de 2
    • Pull the bottom piece towards the back of the mouse and upwards to remove it.
    • Pull carefully there is a ribbon cable still connected.
  7. G-Wolves Hati Paracord Replacement: étape 7, image 1 de 2 G-Wolves Hati Paracord Replacement: étape 7, image 2 de 2
    • Remove the ribbon cable connecting the bottom piece to the upper piece.
  8. G-Wolves Hati Paracord Replacement: étape 8, image 1 de 2 G-Wolves Hati Paracord Replacement: étape 8, image 2 de 2
    • Unscrew the following screws:
    • 4.8 mm Phillips-head screws.
  9. G-Wolves Hati Paracord Replacement: étape 9, image 1 de 2 G-Wolves Hati Paracord Replacement: étape 9, image 2 de 2
    • Flip the bottom piece upside down.
    • Pull the circuit board off without pulling on the cable.
  10. G-Wolves Hati Paracord Replacement: étape 10, image 1 de 3 G-Wolves Hati Paracord Replacement: étape 10, image 2 de 3 G-Wolves Hati Paracord Replacement: étape 10, image 3 de 3
    • Grab the side ridges and remove the connection.
    • Do not wiggle till slightly removed to not bend pins.
  11. G-Wolves Hati Paracord Replacement: étape 11, image 1 de 2 G-Wolves Hati Paracord Replacement: étape 11, image 2 de 2
    • Pop off the paracord from the bottom piece.
  12. G-Wolves Hati Paracord Replacement: étape 12, image 1 de 2 G-Wolves Hati Paracord Replacement: étape 12, image 2 de 2
    • Press in the new paracord.
  13. G-Wolves Hati Paracord Replacement: étape 13, image 1 de 3 G-Wolves Hati Paracord Replacement: étape 13, image 2 de 3 G-Wolves Hati Paracord Replacement: étape 13, image 3 de 3
    • Rearrange wires to follow the guide ridges.
  14. G-Wolves Hati Paracord Replacement: étape 14, image 1 de 2 G-Wolves Hati Paracord Replacement: étape 14, image 2 de 2
    • Re-insert the circuit board by lining up the scroll wheel with the front piece and pressing down.
  15. G-Wolves Hati Paracord Replacement: étape 15, image 1 de 2 G-Wolves Hati Paracord Replacement: étape 15, image 2 de 2
    • Re-insert the screws.
  16. G-Wolves Hati Paracord Replacement: étape 16, image 1 de 2 G-Wolves Hati Paracord Replacement: étape 16, image 2 de 2
    • Thread the wire through the side opening.
    • Insert the paracord connection.
  17. G-Wolves Hati Paracord Replacement: étape 17, image 1 de 2 G-Wolves Hati Paracord Replacement: étape 17, image 2 de 2
    • Insert the ribbon cable.
    • Cable is located on the upper mouse piece.
  18. G-Wolves Hati Paracord Replacement: étape 18, image 1 de 3 G-Wolves Hati Paracord Replacement: étape 18, image 2 de 3 G-Wolves Hati Paracord Replacement: étape 18, image 3 de 3
    • Hover the bottom piece over the upper piece flipped over.
    • Press the bottom piece down and forward till under clip pieces.
    • Press down where skates where removed till there is a click.
  19. G-Wolves Hati Paracord Replacement: étape 19, image 1 de 2 G-Wolves Hati Paracord Replacement: étape 19, image 2 de 2
    • Insert the screws.
    • 6.4mm Phillips Head Screws.
  20. G-Wolves Hati Paracord Replacement: étape 20, image 1 de 3 G-Wolves Hati Paracord Replacement: étape 20, image 2 de 3 G-Wolves Hati Paracord Replacement: étape 20, image 3 de 3
    • Press on the skates.
Ligne d'arrivée
Ayaan
Membre depuis le 10/23/23
301 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 5-11, Kershman Fall 2023 Membre de l'équipe CSU Los Angeles, Team 5-11, Kershman Fall 2023
CSULA-KERSHMAN-F23S5G11
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 45
Total : 215
