Aller au contenu principal
HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement
Ce dont vous avez besoin
  1. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: étape 1, image 1 de 3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: étape 1, image 2 de 3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement, Hard Disk Drive / Solid State Drive: étape 1, image 3 de 3
    • Place the computer screen down on a flat surface.
    • Push the two locking latches to the unlocked position.
    • Push the cover toward the top of the computer and lift up.
  2. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: étape 2, image 1 de 3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: étape 2, image 2 de 3 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: étape 2, image 3 de 3
    • Grasp the handle on the hard drive cage to the left of the stand. It is marked with green.
    • Pull the handle up, allowing the entire cage to slide toward the outward edge of the computer.
    • Pull the entire cage up and out of the device.
  3. HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: étape 3, image 1 de 2 HP EliteOne 800 G1 Hard Disk Drive / Solid State Drive Replacement: étape 3, image 2 de 2
    • Once the cage is out of the device, use a Torx T15 driver to unscrew the four 10mm screws keeping the drive in place. There are two screws on each side.
    • Once all the screws are removed, lift the drive out of the cage.
4 autres ont terminé cette réparation.
Kyle Koivuniemi
Membre depuis le 10/01/15
605 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 1-24, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 1-24, Maness Fall 2015
CPSU-MANESS-F15S1G24
4 membres
14 tutoriels rédigés
2 commentaires
where can i buy a replace cage for the hard drive?
Thomas Dickson - Réponse
What replacement guide can I buy for my HP EliteOne 800 G1 all in one?
Hank Trujillo - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 55
Total : 8,472
