Aller au contenu principal
HP Omen 15-ax200ne Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Omen 15-ax200ne Hard Drive Replacement, Hard Drive: étape 1, image 1 de 1
    • Fully power off the laptop.
    • If you are unsure that your laptop is in hibernation mode, turn the computer off from the start menu.
    • Unplug charging cable and any external devices.
  2. HP Omen 15-ax200ne Hard Drive Replacement: étape 2, image 1 de 1
    Outil utilisé dans cette étape :
    Anti-Static Wrist Strap
    $7.95
    J'achète
    • Position the laptop upside down on a flat and clean surface.
    • Make sure to stay away from static discharge or wear an anti-static wrist strap.
    • Remove the two Phillips M2x5.0 screws located at the top left and top right of the laptop (circled in red).
    • Remove the eight M2.5x6.0 (circled in orange).
  3. HP Omen 15-ax200ne Hard Drive Replacement: étape 3, image 1 de 2 HP Omen 15-ax200ne Hard Drive Replacement: étape 3, image 2 de 2
    • Keep in mind, there are three internal clips by the battery area.
    • Slide the nylon opening tool around the edge of the base enclosure, releasing the three clips by the battery area.
    • Continue to slide the nylon opening tool around the edges of the base enclosure, doing so while loosen the cover.
  4. HP Omen 15-ax200ne Hard Drive Replacement: étape 4, image 1 de 2 HP Omen 15-ax200ne Hard Drive Replacement: étape 4, image 2 de 2
    • After successfully loosening the base enclosure, and removing it. You will be left with an exposed motherboard.
  5. HP Omen 15-ax200ne Hard Drive Replacement: étape 5, image 1 de 3 HP Omen 15-ax200ne Hard Drive Replacement: étape 5, image 2 de 3 HP Omen 15-ax200ne Hard Drive Replacement: étape 5, image 3 de 3
    • Unplug the battery from the motherboard.
    • Release the battery cable from the routing channel to reveal the screws beneath.
  6. HP Omen 15-ax200ne Hard Drive Replacement: étape 6, image 1 de 3 HP Omen 15-ax200ne Hard Drive Replacement: étape 6, image 2 de 3 HP Omen 15-ax200ne Hard Drive Replacement: étape 6, image 3 de 3
    • Remove the four 2x5 screws using the Phillips screwdriver.
    • Slide the battery out of its space to remove it from the computer.
  7. HP Omen 15-ax200ne Hard Drive Replacement: étape 8, image 1 de 3 HP Omen 15-ax200ne Hard Drive Replacement: étape 8, image 2 de 3 HP Omen 15-ax200ne Hard Drive Replacement: étape 8, image 3 de 3
    • Disconnect the clip attaching the hard drive cable to the motherboard.
    • Be careful when disconnecting this clip, as it is very delicate.
    • Use your fingers or a spudger to disconnect the cable. Do not use a screwdriver for the job. It could cause damage.
    • Slide the hard drive out horizontally.
  8. HP Omen 15-ax200ne Hard Drive Replacement: étape 9, image 1 de 1
    • Disassemble the hard drive by removing the connector and the side brackets.
  9. HP Omen 15-ax200ne Hard Drive Replacement: étape 10, image 1 de 2 HP Omen 15-ax200ne Hard Drive Replacement: étape 10, image 2 de 2
    • Reattach the side brackets and the hard drive connector.
  10. HP Omen 15-ax200ne Hard Drive Replacement: étape 11, image 1 de 2 HP Omen 15-ax200ne Hard Drive Replacement: étape 11, image 2 de 2
    • Slide the hard drive back to the original spot.
    • Reclip the hard drive to the motherboard.
Khaled Hamdan
Membre depuis le 01/14/21
193 Réputation
1 tutoriel rédigé
Équipe
York University, Team S2-G8, O'Regan Winter 2021 Membre de l'équipe York University, Team S2-G8, O'Regan Winter 2021
YORK-O'REGAN-W21S2G8
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 37
30 derniers jours : 99
Total : 2,799
