Aller au contenu principal
HTC Desire 510 Front and Main Cameras Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. HTC Desire 510 Front and Main Cameras Replacement, BATTERY REMOVAL: étape 1, image 1 de 3 HTC Desire 510 Front and Main Cameras Replacement, BATTERY REMOVAL: étape 1, image 2 de 3 HTC Desire 510 Front and Main Cameras Replacement, BATTERY REMOVAL: étape 1, image 3 de 3
    • Switch off the phone, remove the battery and any installed SIM and memory cards.
    • Remove 7x Torx T5 screws.
  2. HTC Desire 510 Front and Main Cameras Replacement, REAR BEZEL REMOVAL: étape 2, image 1 de 3 HTC Desire 510 Front and Main Cameras Replacement, REAR BEZEL REMOVAL: étape 2, image 2 de 3 HTC Desire 510 Front and Main Cameras Replacement, REAR BEZEL REMOVAL: étape 2, image 3 de 3
    • Use a plastic tool to remove the rear bezel.
    • The loudspeaker is on the inner side of the rear bezel.
  3. HTC Desire 510 Front and Main Cameras Replacement, FLEX CABLES DISCONNECTING: étape 3, image 1 de 3 HTC Desire 510 Front and Main Cameras Replacement, FLEX CABLES DISCONNECTING: étape 3, image 2 de 3 HTC Desire 510 Front and Main Cameras Replacement, FLEX CABLES DISCONNECTING: étape 3, image 3 de 3
    • Disconnect the touch screen flex cable.
    • Disconnect the light sensor flex cable.
    • Unstuck the vibra-motor from the middle frame.
    • Remove the coaxial antenna cable from the middle frame.
    • The LCD display flex cable is connected to the bottom side of the board.
  4. HTC Desire 510 Front and Main Cameras Replacement, LOGIC BOARD REMOVAL: étape 4, image 1 de 3 HTC Desire 510 Front and Main Cameras Replacement, LOGIC BOARD REMOVAL: étape 4, image 2 de 3 HTC Desire 510 Front and Main Cameras Replacement, LOGIC BOARD REMOVAL: étape 4, image 3 de 3
    • At the upper left side, the board is held by a plastic locking clip. Use a plastic tool and start the separating from here.
    • Gently disconnect the LCD display flex cable.
    • Now remove the logic board.
  5. HTC Desire 510 Front and Main Cameras Replacement, Front and Main Cameras: étape 5, image 1 de 2 HTC Desire 510 Front and Main Cameras Replacement, Front and Main Cameras: étape 5, image 2 de 2
    • Main / Rear camera.
    • New line.
2 autres ont terminé cette réparation.
ZFix
Membre depuis le 12/09/13
191 647 Réputation
330 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
321 membres
1 501 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 12
Total : 1,565
