Aller au contenu principal
Handspring Visor Deluxe PDA Touch Screen Replacement
Ce dont vous avez besoin
  1. Handspring Visor Deluxe PDA Touch Screen Replacement, Outside cover and stylus: étape 1, image 1 de 2 Handspring Visor Deluxe PDA Touch Screen Replacement, Outside cover and stylus: étape 1, image 2 de 2
    • Remove the outer screen cover by releasing the top clip from the main body of the device.
  2. Handspring Visor Deluxe PDA Touch Screen Replacement: étape 2, image 1 de 3 Handspring Visor Deluxe PDA Touch Screen Replacement: étape 2, image 2 de 3 Handspring Visor Deluxe PDA Touch Screen Replacement: étape 2, image 3 de 3
    • Pull out the stylus from the top right corner of the device.
  3. Handspring Visor Deluxe PDA Touch Screen Replacement: étape 3, image 1 de 3 Handspring Visor Deluxe PDA Touch Screen Replacement: étape 3, image 2 de 3 Handspring Visor Deluxe PDA Touch Screen Replacement: étape 3, image 3 de 3
    • Slide the memory cartridge cover up and off the device.
  4. Handspring Visor Deluxe PDA Touch Screen Replacement, Batteries: étape 4, image 1 de 2 Handspring Visor Deluxe PDA Touch Screen Replacement, Batteries: étape 4, image 2 de 2
    • Remove the battery cover by releasing the clip from the main body of the device.
  5. Handspring Visor Deluxe PDA Touch Screen Replacement: étape 5, image 1 de 1
    • Remove the batteries from the device.
  6. Handspring Visor Deluxe PDA Touch Screen Replacement, Back Cover: étape 6, image 1 de 1
    • Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
    • One end of the OEM stylus can unscrew and contains a mini #00 Phillips screwdriver.
  7. Handspring Visor Deluxe PDA Touch Screen Replacement: étape 7, image 1 de 3 Handspring Visor Deluxe PDA Touch Screen Replacement: étape 7, image 2 de 3 Handspring Visor Deluxe PDA Touch Screen Replacement: étape 7, image 3 de 3
    • Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
    • Be careful while opening the casing as there is a flex strip connecting the two halves.
  8. Handspring Visor Deluxe PDA Touch Screen Replacement: étape 8, image 1 de 3 Handspring Visor Deluxe PDA Touch Screen Replacement: étape 8, image 2 de 3 Handspring Visor Deluxe PDA Touch Screen Replacement: étape 8, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Disconnect the flex strip from the motherboard with tweezers.
  9. Handspring Visor Deluxe PDA Touch Screen Replacement, Touch Screen: étape 9, image 1 de 3 Handspring Visor Deluxe PDA Touch Screen Replacement, Touch Screen: étape 9, image 2 de 3 Handspring Visor Deluxe PDA Touch Screen Replacement, Touch Screen: étape 9, image 3 de 3
    • Release the latch in bottom right corner of the touchscreen.
    • Use the spudger (if needed) to pry the screen from the front case.
David Faltemier
Membre depuis le 06/20/12
19 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 1-2, Regan SU 2012 Membre de l'équipe Cal Poly, Team 1-2, Regan SU 2012
CPSU-REGAN-SU12S1G2
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 11
Total : 857
