Aller au contenu principal
Handspring Visor Edge Speaker Replacement
Ce dont vous avez besoin
  1. Handspring Visor Edge Speaker Replacement, Flip Cover: étape 1, image 1 de 2 Handspring Visor Edge Speaker Replacement, Flip Cover: étape 1, image 2 de 2
    • Open the Visor Edge and place it on a table facing down.
    • Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
    • Do not pull on the flip cover in an attempt to remove it from the PDA.
  2. Handspring Visor Edge Speaker Replacement, Back Panel: étape 2, image 1 de 1
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Speaker Replacement: étape 3, image 1 de 1
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Speaker Replacement: étape 4, image 1 de 2 Handspring Visor Edge Speaker Replacement: étape 4, image 2 de 2
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Speaker Replacement: étape 5, image 1 de 2 Handspring Visor Edge Speaker Replacement: étape 5, image 2 de 2
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Speaker Replacement: étape 6, image 1 de 1
    • Gently remove the white frame from the back of the PDA.
  7. Handspring Visor Edge Speaker Replacement, Speaker: étape 7, image 1 de 1
    • Gently pull off front cover.
  8. Handspring Visor Edge Speaker Replacement: étape 8, image 1 de 1
    • Gently remove buttons by hand.
  9. Handspring Visor Edge Speaker Replacement: étape 9, image 1 de 1
    • Pull off button board.
    • (The button board is located underneath the buttons).
  10. Handspring Visor Edge Speaker Replacement: étape 10, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Carefully remove the speaker by pulling on the body of the plug with a pair of tweezers, rocking it from side to side to ease it if necessary.
    • Pull in the same direction as the individual wires are running and make sure to evenly on the full width of the cable so that no individual wires are overly strained.
Nick Lazarakis
Membre depuis le 01/23/11
331 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 11-28, Maness Winter 2011 Membre de l'équipe Cal Poly, Team 11-28, Maness Winter 2011
CPSU-MANESS-W11S11G28
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 806
