Introduction
This guide will show you how to replace the oil in your vehicle using an oil extractor/pump. The vehicle being serviced in this guide is an Audi S5; the location of your filter and dipstick may differ.
Please note this method only works if the oil filter is located in the engine bay. The filter may also be located underneath the engine, next to the oil pan. Gloves are recommended, but not required. Avoid getting engine oil in the face or eyes. If this occurs, rinse your eyes immediately.
Before beginning this guide, turn the car's ignition off, place the car in park, and engage the parking brake.
Ce dont vous avez besoin
Open the engine bay and locate the oil filter, oil fill hole, and dipstick/oil suction hole.
Break the oil filter loose with a ratchet or filter wrench.
If the filter has a housing, remove the filter assembly and replace the filter inside.
Replace the O-ring. (A screwdriver may make this process easier.) Make sure the O-ring goes back into the same slot as before and lubricate it with some oil.
Start the vehicle, check for leaks, and ensure the oil pressure is within normal range if a gauge is available.
