Aller au contenu principal
How to Darn a Sock
Ce dont vous avez besoin
  1. How to Darn a Sock, How to Darn a Sock: étape 1, image 1 de 2 How to Darn a Sock, How to Darn a Sock: étape 1, image 2 de 2
    • Insert a darning egg (or substitute object) into the sock until the hole is stretched out.
  2. How to Darn a Sock: étape 2, image 1 de 2 How to Darn a Sock: étape 2, image 2 de 2
    • Sew a running stitch around the hole to reinforce it.
    • To make a running stitch, move your needle in and out of the sock a fixed distance apart.
    • The needle is sharp; use caution and avoid poking your hand.
  3. How to Darn a Sock: étape 3, image 1 de 2 How to Darn a Sock: étape 3, image 2 de 2
    • Start a stitch from one side of the hole, about ½” to ⅛” away. Connect one side of the hole to the other using the thread.
    • Run parallel stitches until the hole is fully covered.
  4. How to Darn a Sock: étape 4, image 1 de 2 How to Darn a Sock: étape 4, image 2 de 2
    • Rotate your sock 90 degrees, then repeat step 4 to create a patch.
  5. How to Darn a Sock: étape 5, image 1 de 2 How to Darn a Sock: étape 5, image 2 de 2
    • Weave the extra thread into the sock's fabric, then cut the needle away from the thread.
Ligne d'arrivée
justinHo910
Membre depuis le 10/24/23
121 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 1-1, Briggs Fall 2023 Membre de l'équipe CSU Los Angeles, Team 1-1, Briggs Fall 2023
CSULA-BRIGGS-F23S1G1
6 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 18
30 derniers jours : 58
Total : 226
