Aller au contenu principal
How to Fill a Crack in a Glass Container
Ce dont vous avez besoin
  1. How to Fill a Crack in a Glass Container, How to Fill a Crack in a Glass Container: étape 1, image 1 de 3 How to Fill a Crack in a Glass Container, How to Fill a Crack in a Glass Container: étape 1, image 2 de 3 How to Fill a Crack in a Glass Container, How to Fill a Crack in a Glass Container: étape 1, image 3 de 3
    • Clean the jar or vase with dish soap to remove all dust, fingerprints and dirt.
    • Using a tool such as a sponge or brush is optional but will work better than just your hands.
    • Dry the glass using a paper towel, and allow it time to completely dry.
  2. How to Fill a Crack in a Glass Container: étape 2, image 1 de 3 How to Fill a Crack in a Glass Container: étape 2, image 2 de 3 How to Fill a Crack in a Glass Container: étape 2, image 3 de 3
    • Be sure to follow the directions on the specific two part epoxy product you’re using.
    • Mix the two-part epoxy on a piece of cardboard or a disposable plate.
    • Use a toothpick to mix the epoxy for at least 20 seconds.
    • After the epoxy is mixed, be ready to use it immediately, as it will quickly thicken and harden. Oftentimes you will have between 5 -10 minutes of working time before the epoxy is too thick and hard to use.
  3. How to Fill a Crack in a Glass Container: étape 3, image 1 de 3 How to Fill a Crack in a Glass Container: étape 3, image 2 de 3 How to Fill a Crack in a Glass Container: étape 3, image 3 de 3
    • Apply the epoxy to the crack in the glass using a putty knife. Work the adhesive back and forth across the crack, pressing the epoxy into the damaged area.
    • Be sure to fully cover the damaged area.
    • Ensure you use enough pressure to get the epoxy into the crack but not too pressure that could further crack the glass.
    • Allow the epoxy to cure for at least 5 minutes.
  4. How to Fill a Crack in a Glass Container: étape 4, image 1 de 3 How to Fill a Crack in a Glass Container: étape 4, image 2 de 3 How to Fill a Crack in a Glass Container: étape 4, image 3 de 3
    • Remove the excess epoxy with a razor blade.
    • Be careful when using the razor blaze to ensure you do not injure yourself or further crack the glass
    • Wipe the crack with a clean rag moistened with acetone to remove any additional epoxy raised above the crack.
    • Allow the glass to cure for at least 24 hours.
  5. How to Fill a Crack in a Glass Container: étape 5, image 1 de 3 How to Fill a Crack in a Glass Container: étape 5, image 2 de 3 How to Fill a Crack in a Glass Container: étape 5, image 3 de 3
    • After 24 hours, polish the newly repaired glass with a clean rag and glass cleaner.
Thanks for following our guide! We hope it was simple and helped you to reduce your amount of waste!!
M Keating
Membre depuis le 07/05/23
148 Réputation
1 tutoriel rédigé
Équipe
Austin Community College, Team 1-3, Meigs Summer 2023 Membre de l'équipe Austin Community College, Team 1-3, Meigs Summer 2023
AUSTINCC-MEIGS-SU23S1G3
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 39
30 derniers jours : 151
Total : 895
