Aller au contenu principal
How to Fix a Broken Strap on a Strapback Hat
Ce dont vous avez besoin
  1. How to Fix a Broken Strap on a Strapback Hat, How to Fix a Broken Strap on a Strapback Hat: étape 1, image 1 de 3 How to Fix a Broken Strap on a Strapback Hat, How to Fix a Broken Strap on a Strapback Hat: étape 1, image 2 de 3 How to Fix a Broken Strap on a Strapback Hat, How to Fix a Broken Strap on a Strapback Hat: étape 1, image 3 de 3
    • Measure the thread.
    • We recommend an arms-length amount of thread to ensure its enough to complete the fix without needing more thread.
    • Cut the thread at desired length.
  2. How to Fix a Broken Strap on a Strapback Hat: étape 2, image 1 de 2 How to Fix a Broken Strap on a Strapback Hat: étape 2, image 2 de 2
    • Thread the needle.
  3. How to Fix a Broken Strap on a Strapback Hat: étape 3, image 1 de 2 How to Fix a Broken Strap on a Strapback Hat: étape 3, image 2 de 2
    • Pull the thread through the needle until both ends of the thread meet.
    • Tie a knot at the end of the thread.
  4. How to Fix a Broken Strap on a Strapback Hat: étape 4, image 1 de 2 How to Fix a Broken Strap on a Strapback Hat: étape 4, image 2 de 2
    • Position the strap to where it was originally located on the hat.
  5. How to Fix a Broken Strap on a Strapback Hat: étape 5, image 1 de 2 How to Fix a Broken Strap on a Strapback Hat: étape 5, image 2 de 2
    • Ensure that the strap doesn't move by using a binder clip to hold it in place.
  6. How to Fix a Broken Strap on a Strapback Hat: étape 6, image 1 de 3 How to Fix a Broken Strap on a Strapback Hat: étape 6, image 2 de 3 How to Fix a Broken Strap on a Strapback Hat: étape 6, image 3 de 3
    • Starting on the inside of the hat, poke the needle through the cap and loose strap.
    • Pull the needle through the fabric and out the other end.
  7. How to Fix a Broken Strap on a Strapback Hat: étape 7, image 1 de 2 How to Fix a Broken Strap on a Strapback Hat: étape 7, image 2 de 2
    • Move the needle a few millimeters to the left and poke the needle through the front of the hat.
    • Pull the needle out on the other end.
  8. How to Fix a Broken Strap on a Strapback Hat: étape 8, image 1 de 2 How to Fix a Broken Strap on a Strapback Hat: étape 8, image 2 de 2
    • Repeat steps 6 and 7 until the strap is fully sewn onto the hat.
  9. How to Fix a Broken Strap on a Strapback Hat: étape 9, image 1 de 3 How to Fix a Broken Strap on a Strapback Hat: étape 9, image 2 de 3 How to Fix a Broken Strap on a Strapback Hat: étape 9, image 3 de 3
    • Tie a knot as close to the base of the hat as possible and cut the thread.
  10. How to Fix a Broken Strap on a Strapback Hat: étape 10, image 1 de 1
    • Your hat is fixed and ready to wear!
Congratulations! With some simple hand sewing, you were able to fix the broken strap on your hat.
Sarah Sy
Membre depuis le 02/02/23
181 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 1-1, Andersen Winter 2023 Membre de l'équipe UC Davis, Team 1-1, Andersen Winter 2023
UCD-ANDERSEN-W23S1G1
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 102
30 derniers jours : 332
Total : 3,228
