Aller au contenu principal
How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828
Ce dont vous avez besoin
  1. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828, How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: étape 1, image 1 de 2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828, How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: étape 1, image 2 de 2
    • Slide the button back to open the battery cover.
  2. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: étape 2, image 1 de 2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: étape 2, image 2 de 2
    • Pull back on the tab to release the battery.
    • Pull the battery out, then close the lid.
  3. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: étape 3, image 1 de 1
    • Remove the screw on the back of the turret with a JIS #00 screwdriver.
  4. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: étape 4, image 1 de 2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: étape 4, image 2 de 2
    • Remove two screws from each side of the camera (four in total) using a JIS #00 screwdriver.
  5. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: étape 5, image 1 de 1
    • Remove the screw on the bottom of the turret using a JIS #00 screwdriver.
  6. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: étape 6, image 1 de 1
    • Carefully pull the face plate off and lay it down.
    • There is a cable attached to the plate that should not be removed.
  7. How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: étape 7, image 1 de 2 How to Fix a Loose Turret on a Sony Cyber-shot DSC-F828: étape 7, image 2 de 2
    • Tighten the two screws using a JIS #00 screwdriver.
5 autres ont terminé cette réparation.
Un commentaire
Thanks, I just used this to tighten the pivot on an F828 I got on eBay. Super easy.
photoman12001 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 27
Total : 1,134
