Aller au contenu principal
How to Fix a Skewed Wheel on a Children's Kick Scooter
Ce dont vous avez besoin
  1. How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 1, image 1 de 3 How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 1, image 2 de 3 How to Fix a Skewed Wheel on a Children's Kick Scooter, How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 1, image 3 de 3
    • Remove the two bottom 16 mm pan head screws using a Phillips #1 screwdriver.
  2. How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 2, image 1 de 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 2, image 2 de 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 2, image 3 de 3
    • Remove the two 12 mm button head screws on top using a 4 mm Allen wrench.
  3. How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 3, image 1 de 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 3, image 2 de 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 3, image 3 de 3
    • Remove the plastic case from the base of the scooter.
  4. How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 4, image 1 de 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 4, image 2 de 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 4, image 3 de 3
    • Carefully pull the sides of the wheels up and remove them from the spring.
  5. How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 5, image 1 de 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 5, image 2 de 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 5, image 3 de 3
    • Grab the spring with combination pliers and bend it into a straight position.
    • Don't bend the spring too much as it could snap and replacement would be needed.
  6. How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 6, image 1 de 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 6, image 2 de 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 6, image 3 de 3
    • Insert the spring into the center section of the wheels.
    • Slide the two rings on the sides of the wheels into the two rods.
  7. How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 7, image 1 de 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 7, image 2 de 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 7, image 3 de 3
    • Insert the plastic case back into its original position.
  8. How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 8, image 1 de 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 8, image 2 de 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 8, image 3 de 3
    • Insert and tighten the two 12 mm button head screws on top using a 4 mm Allen wrench.
  9. How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 9, image 1 de 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 9, image 2 de 3 How to Fix a Skewed Wheel on a Children's Kick Scooter: étape 9, image 3 de 3
    • Replace the two bottom 16 mm pan head screws using a Phillips #1 screwdriver.
Ligne d'arrivée
Amir Issagali
Membre depuis le 01/10/21
169 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G14, O'Regan Winter 2021 Membre de l'équipe York University, Team S1-G14, O'Regan Winter 2021
YORK-O'REGAN-W21S1G14
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 26
Total : 1,415
