Aller au contenu principal
How to Install an HID Conversion Kit
Ce dont vous avez besoin
  1. How to Install an HID Conversion Kit, Headlights: étape 1, image 1 de 2 How to Install an HID Conversion Kit, Headlights: étape 1, image 2 de 2
    • Open the hood.
    • Locate the back of the headlights and remove the bolts holding the headlight housing.
  2. How to Install an HID Conversion Kit: étape 2, image 1 de 1
    • Unplug the stock harness and remove the headlights.
  3. How to Install an HID Conversion Kit: étape 3, image 1 de 2 How to Install an HID Conversion Kit: étape 3, image 2 de 2
    • Remove battery negative terminal.
    • Remove headlight cover and remove factory halogen bulb.
  4. How to Install an HID Conversion Kit: étape 4, image 1 de 1
    • Take out the HID bulb from the plastic shell and remove the circular plastic piece.
    • Remember not to touch the HID bulb glass!
    • If you accidentally touch it, you can clean it with some rubbing alcohol.
  5. How to Install an HID Conversion Kit: étape 5, image 1 de 2 How to Install an HID Conversion Kit: étape 5, image 2 de 2
    • Screw in the HID bulb back into the headlight housing.
    • Connect the wires of the HID bulb to the ballast and then connect the HID ballast back to the stock harness.
  6. How to Install an HID Conversion Kit: étape 6, image 1 de 1
    • Before you mount the ballast, test the HID light to make sure it lights up.
    • If not, turn the adapter wire 180 degrees.
    • Mount the HID ballast with zip ties.
  7. How to Install an HID Conversion Kit: étape 7, image 1 de 3 How to Install an HID Conversion Kit: étape 7, image 2 de 3 How to Install an HID Conversion Kit: étape 7, image 3 de 3
    • Put everything (like the headlight housing) back.
    • Enjoy!
Enjoy your new HID Conversion Kit and upgraded headlights or fog lights.
6 autres ont terminé cette réparation.
Eric Wu
Membre depuis le 01/21/15
3 357 Réputation
23 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 18
30 derniers jours : 103
Total : 16,313
