Aller au contenu principal
How to Patch a Tear in Vinyl Furniture
Ce dont vous avez besoin
  1. How to Patch a Tear in Vinyl Furniture, How to Patch a Tear in Vinyl Furniture: étape 1, image 1 de 1
    • Clean the damaged area with rubbing alcohol, using a rag, paper towel, or Q-tip.
  2. How to Patch a Tear in Vinyl Furniture: étape 2, image 1 de 1
    • Cut the backing fabric large enough to cover the tear, approximately half an inch larger around the tear.
  3. How to Patch a Tear in Vinyl Furniture: étape 3, image 1 de 2 How to Patch a Tear in Vinyl Furniture: étape 3, image 2 de 2
    • Use the spatula tool to insert the backing fabric underneath the tear.
  4. How to Patch a Tear in Vinyl Furniture: étape 4, image 1 de 2 How to Patch a Tear in Vinyl Furniture: étape 4, image 2 de 2
    • Use the spatula to apply the adhesive to the damaged area.
    • Choose a color that matches your furniture. You may need to mix colors to acheive the correct shade.
  5. How to Patch a Tear in Vinyl Furniture: étape 5, image 1 de 1
    • Let the adhesive dry for approximately four hours.
    • You may use a hair dryer to speed up the drying process.
  6. How to Patch a Tear in Vinyl Furniture: étape 6, image 1 de 2 How to Patch a Tear in Vinyl Furniture: étape 6, image 2 de 2
    • Use a Q-tip dipped in rubbing alcohol to buff and blend the area.
    • Apply light pressure to even out the edges.
Once the adhesive is dry, the furniture is ready for use!
4 autres ont terminé cette réparation.
Bailey Arman
Membre depuis le 09/19/18
188 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 55
30 derniers jours : 235
Total : 25,111
