Aller au contenu principal
How to Realign a Door Hinge
Ce dont vous avez besoin
  1. How to Realign a Door Hinge, How to Realign a Door Hinge: étape 1, image 1 de 3 How to Realign a Door Hinge, How to Realign a Door Hinge: étape 1, image 2 de 3 How to Realign a Door Hinge, How to Realign a Door Hinge: étape 1, image 3 de 3
    • Grab an unaligned door.
    • Either you or a person who is helping hold the door up to the desired position.
  2. How to Realign a Door Hinge: étape 2, image 1 de 3 How to Realign a Door Hinge: étape 2, image 2 de 3 How to Realign a Door Hinge: étape 2, image 3 de 3
    • Grab a hammer and a screwdriver.
    • Hold the screwdriver up to the pin.
    • Hold the hammer below the screwdriver.
    • Knock the pin out of the hinge by banging the screwdriver using the hammer.
  3. How to Realign a Door Hinge: étape 3, image 1 de 3 How to Realign a Door Hinge: étape 3, image 2 de 3 How to Realign a Door Hinge: étape 3, image 3 de 3
    • Drop the pin back into the hinge using the hammer.
    • If the pin gets stuck this means that the knuckles need to be bent back into place.
    • Using pliers bend whichever knuckles need adjusting.
    • Keep bending the knuckles until the pin drops back into place without getting stuck.
  4. How to Realign a Door Hinge: étape 4, image 1 de 1
    • The door should now be in your desired position.
    • To test if the door is back in place, just open and close the door to make sure that the door is in the position you want and functioning correctly.
You have now successfully realigned a door hinge! Good Job
andrea hernandez
Membre depuis le 10/23/23
109 Réputation
1 tutoriel rédigé
Équipe
Sam Houston State, Team 1-8, Bennett Fall 2023 Membre de l'équipe Sam Houston State, Team 1-8, Bennett Fall 2023
SHSU-BENNETT-F23S1G8
2 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 19
30 derniers jours : 117
Total : 412
