Aller au contenu principal
How to Refurbish White Adidas Continental 80 Shoes
Ce dont vous avez besoin
  1. How to Refurbish White Adidas Continental 80 Shoes, How to Refurbish White Adidas Continental 80 Shoes: étape 1, image 1 de 1
    • Take the laces out of both shoes before cleaning.
    • The laces can be either hand-washed or put through the washer and dryer after the shoes are cleaned.
  2. How to Refurbish White Adidas Continental 80 Shoes: étape 2, image 1 de 1
    • Wet the brush in soapy water.
    • Brush the base of the shoe horizontally and vertically.
    • Wet the brush multiple times to keep enough soapy water on the shoe.
  3. How to Refurbish White Adidas Continental 80 Shoes: étape 3, image 1 de 1
    • Brush the top and different sections of the shoe.
    • Continue with circular, vertical, and horizontal brushing motions to ensure the best results.
  4. How to Refurbish White Adidas Continental 80 Shoes: étape 4, image 1 de 1
    • Make sure to clean the tongue in the same circular, horizontal, and vertical motions with the toothbrush.
    • Use lots of soapy water on the tongue.
  5. How to Refurbish White Adidas Continental 80 Shoes: étape 5, image 1 de 1
    • Grab a new bowl with warm water and wet the hand-towel to remove the dirt accumulated by the soapy water.
    • Wet and wipe multiple times to remove excess soap from the shoe.
  6. How to Refurbish White Adidas Continental 80 Shoes: étape 6, image 1 de 1
    • Set the right shoe aside and move on to the left shoe.
  7. How to Refurbish White Adidas Continental 80 Shoes: étape 7, image 1 de 1
    • Brush the base and sides in the same circular, horizontal, and vertical motions with the toothbrush.
  8. How to Refurbish White Adidas Continental 80 Shoes: étape 8, image 1 de 1
    • Brush the top and tongue of the left shoe.
    • Continue rinsing and re-wetting the toothbrush in soapy water.
  9. How to Refurbish White Adidas Continental 80 Shoes: étape 9, image 1 de 1
    • See if there are any other areas of the shoe you might need to clean again.
  10. How to Refurbish White Adidas Continental 80 Shoes: étape 10, image 1 de 1
    • Soak the laces in the same soapy water you used to clean your shoes for 30-40 minutes.
  11. How to Refurbish White Adidas Continental 80 Shoes: étape 11, image 1 de 1
    • Soak the laces in clean water for 30-40 minutes to clean off the soap.
    • Soak the laces at room temperature to prevent the laces from shriveling up.
  12. How to Refurbish White Adidas Continental 80 Shoes: étape 12, image 1 de 1
    • Let the laces air dry for 1-2 hours or put them in the dryer for 20 minutes.
  13. How to Refurbish White Adidas Continental 80 Shoes: étape 13, image 1 de 1
    • Let your shoes sit out to air dry for an entire day.
    • Avoid putting shoes in the dryer unless you have protective material around your shoes to prevent damage.
Having clean shoes is important to a lot of people. Know that this technique is a simple, easy technique with simple materials used. There are plenty of more in-depth, expensive techniques that may clean the shoes a lot better than this technique does.
Samir Ochoa
Membre depuis le 10/20/20
244 Réputation
1 tutoriel rédigé
Équipe
Texas Tech, Team S14-G5, Cowan Fall 2020 Membre de l'équipe Texas Tech, Team S14-G5, Cowan Fall 2020
TTU-COWAN-F20S14G5
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 28
30 derniers jours : 87
Total : 4,430
