Introduction
Reinforcing seams is useful when you want your clothes to last longer. All you need are some sewing materials, a chunk of time to dedicate to the process, and the cautiousness not to poke yourself. You are going to want your thread to match your clothes but for this guide, I will be using red so you can see it easily.
Ce dont vous avez besoin
Turn your clothes inside out and locate the seam you want to reinforce.
Poke a straight pin through the clear elastic and fabric at one end of the seam you are reinforcing.
Bend the fabric when part of your pin is through so it is visible on your side again.
Make the fabric level so it is not bunched up. Continue this process of putting pins in until you reach the other end of the seam.
Make sure both string sides are roughly the same length and cut the string that is still connected to the spool of thread.
Tie a knot at the end of your string to hold your thread together. Make the knot by forming a circle and putting your sewing needle through it.
Cut off the excess thread that is past the knot.
