Aller au contenu principal
How to Remove Dinner Plate Scratches
Ce dont vous avez besoin
  1. How to Remove Dinner Plate Scratches, How to Remove Dinner Plate Scratches: étape 1, image 1 de 1
    • Obtain a product called "Bar Keeper's Friend".
    • This product can be found at most grocery stores in the cleaning aisle. (It is available at Walmart)
  2. How to Remove Dinner Plate Scratches: étape 2, image 1 de 1
    • Go to a sink so that you have access to running water.
    • Rinse off your dish so that the plate is moist.
  3. How to Remove Dinner Plate Scratches: étape 3, image 1 de 1
    • Shake some of the "Bar Cleaner's Friend" powder onto the back of the plate to make sure that it does not damage the coloring.
    • Wet the sponge and wipe the plate to see if the product is damaging to your plate.
    • If it is, then stop usage immediately and rinse your plate to reduce damage.
    • If the product is not damaging, then continue use on the top of the plate.
    • Do not consume "Bar Cleaner's Friend" directly.
  4. How to Remove Dinner Plate Scratches: étape 4, image 1 de 2 How to Remove Dinner Plate Scratches: étape 4, image 2 de 2
    • Once you have flipped the plate over and sprinkled the plate with an thin and even layer of "Bar Keeper's Friend", scrub the plate with a sponge until the scratches are less visible.
  5. How to Remove Dinner Plate Scratches: étape 5, image 1 de 1
    • When the powder and water are combined, a paste will form, as shown.
  6. How to Remove Dinner Plate Scratches: étape 6, image 1 de 1
    • Once you have wiped the plate to your satisfaction (until most or all of the scratches have disappeared), squeeze out your sponge and rinse your plate and hands.
  7. How to Remove Dinner Plate Scratches: étape 7, image 1 de 2 How to Remove Dinner Plate Scratches: étape 7, image 2 de 2
    • Now, grab a paper towel and dry your plate by wiping.
    • When you have dried the plate completely, your plate is done and ready for use.
Now you have a plate that looks good as new! To maintain the appearance of your dishware, simply use the same process described in this guide when scratches appear again.
4 autres ont terminé cette réparation.
Julia Trenkle
Membre depuis le 04/09/15
247 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 30-3, Green Spring 2015 Membre de l'équipe Cal Poly, Team 30-3, Green Spring 2015
CPSU-GREEN-S15S30G3
4 membres
10 tutoriels rédigés
Un commentaire
I can’t get Bartender’s friend, but it inspired me to try a ceramic stove top cleaner. It worked like a charm. I was going to throw those dishes away. I have had them for 25 years. Now they will last at least another 15…
Tracee Meyn - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 48
Total : 5,149
