Aller au contenu principal
How to Repair a Broken Jump Ring
Ce dont vous avez besoin
  1. How to Repair a Broken Jump Ring, How to Repair a Broken Jump Ring: étape 1, image 1 de 1
    • Firmly grasp the broken jump ring using one set of small needle-nose pliers.
    • Make sure that the ring's opening is not blocked by the pliers.
  2. How to Repair a Broken Jump Ring: étape 2, image 1 de 1
    • Grasp the opposite side of the jump ring with your other pair of small needle noise pliers.
  3. How to Repair a Broken Jump Ring: étape 3, image 1 de 1
    • Gently twist the pliers in opposite directions until the gap is wide enough to reattach the jump ring to the ear wire.
  4. How to Repair a Broken Jump Ring: étape 4, image 1 de 2 How to Repair a Broken Jump Ring: étape 4, image 2 de 2
    • Grasp the ear wire (if applicable) and insert its loop into the opening of the jump ring.
  5. How to Repair a Broken Jump Ring: étape 5, image 1 de 2 How to Repair a Broken Jump Ring: étape 5, image 2 de 2
    • Insert your earring into the opening of the jump ring.
  6. How to Repair a Broken Jump Ring: étape 6, image 1 de 2 How to Repair a Broken Jump Ring: étape 6, image 2 de 2
    • Grasp the jump ring between your two pairs of pliers and push/twist the two ends of the ring toward each other, until the two ends meet and the gap is closed.
    • Make sure that the gap is closed tight!
Your earrings are ready to be worn again!
ANDREA C TORRES-MARTELL
Membre depuis le 03/18/22
133 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 35
Total : 1,040
