Aller au contenu principal
How to Repair a Burnt Wire for a Light Globe
Ce dont vous avez besoin
  1. How to Repair a Burnt Wire for a Light Globe, How to Repair a Burnt Wire for a Light Globe: étape 1, image 1 de 2 How to Repair a Burnt Wire for a Light Globe, How to Repair a Burnt Wire for a Light Globe: étape 1, image 2 de 2
    • Use a flathead screwdriver to remove the two 3 mm screws from the power adapter.
  2. How to Repair a Burnt Wire for a Light Globe: étape 2, image 1 de 1
    • If needed, clean the power adapter's shell as much as possible.
  3. How to Repair a Burnt Wire for a Light Globe: étape 3, image 1 de 1
    • Use wire cutters to cut the wires to equal lengths.
  4. How to Repair a Burnt Wire for a Light Globe: étape 4, image 1 de 1
    • Use wire strippers to carefully peel the wire cord to expose 2 cm of wire.
  5. How to Repair a Burnt Wire for a Light Globe: étape 5, image 1 de 1
    • Slide the shell back into the wire cord, past the exposed copper wires.
  6. How to Repair a Burnt Wire for a Light Globe: étape 6, image 1 de 3 How to Repair a Burnt Wire for a Light Globe: étape 6, image 2 de 3 How to Repair a Burnt Wire for a Light Globe: étape 6, image 3 de 3
    • Grab the terminal of the power adapter and loosen the 3 mm screws of the terminal if needed.
    • Wrap one exposed copper wire around one loosened 3 mm screw and tighten the screw immediately.
    • Repeat the second bullet point for the second copper wire.
  7. How to Repair a Burnt Wire for a Light Globe: étape 7, image 1 de 2 How to Repair a Burnt Wire for a Light Globe: étape 7, image 2 de 2
    • Push the shell back into the terminal so that the terminal is protected by the shell.
    • Grab the 3 mm screws that were taken out in the first step and re-screw them into the shell.
  8. How to Repair a Burnt Wire for a Light Globe: étape 8, image 1 de 2 How to Repair a Burnt Wire for a Light Globe: étape 8, image 2 de 2
    • Plug in the power adapter into a functioning power outlet.
    • The light globe should now successfully turn on!
Ligne d'arrivée
HarpreetGill
Membre depuis le 05/11/20
157 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G10, O'Regan Summer 2020 Membre de l'équipe York University, Team S1-G10, O'Regan Summer 2020
YORK-O'REGAN-SU20S1G10
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 16
Total : 454
