Aller au contenu principal
How to Repair a Cracked Mirror
Ce dont vous avez besoin
  1. How to Repair a Cracked Mirror, How to Repair a Cracked Mirror: étape 1, image 1 de 1
    • Clean the mirror with soap and water.
  2. How to Repair a Cracked Mirror: étape 2, image 1 de 3 How to Repair a Cracked Mirror: étape 2, image 2 de 3 How to Repair a Cracked Mirror: étape 2, image 3 de 3
    • Remove the adhesive backing of the stabilizer film.
    • Press the stabilizer film over the crack.
    • Use your fingers to smooth out the stabilizer film.
  3. How to Repair a Cracked Mirror: étape 3, image 1 de 1
    • Fill the syringe with epoxy resin.
  4. How to Repair a Cracked Mirror: étape 4, image 1 de 2 How to Repair a Cracked Mirror: étape 4, image 2 de 2
    • Insert the tip of the syringe through the stabilizer film.
    • Push down the plunger to fill the crack with resin.
  5. How to Repair a Cracked Mirror: étape 5, image 1 de 1
    • Set a timer for 20 mins and wait for the resin to harden.
  6. How to Repair a Cracked Mirror: étape 6, image 1 de 1
    • Peel off the stabilizer film.
  7. How to Repair a Cracked Mirror: étape 7, image 1 de 2 How to Repair a Cracked Mirror: étape 7, image 2 de 2
    • Add a drop of resin over the crack.
    • Cover the resin with the curing film.
  8. How to Repair a Cracked Mirror: étape 8, image 1 de 1
    • Set a timer for 1 hour and wait for the resin to cure.
  9. How to Repair a Cracked Mirror: étape 9, image 1 de 2 How to Repair a Cracked Mirror: étape 9, image 2 de 2
    • Remove the curing film.
    • Scrape away any excess resin using the razor blade.
    • Use caution when handling the razor blade as you do not want to cut yourself during the process.
  10. How to Repair a Cracked Mirror: étape 10, image 1 de 1
    • Clean the area with glass cleaner.
Marriam Shaikh
Membre depuis le 09/18/23
181 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 55
30 derniers jours : 259
Total : 574
