Aller au contenu principal
How to Repair a Painting Frame
Ce dont vous avez besoin
  1. How to Repair a Painting Frame, How to Repair a Painting Frame: étape 1, image 1 de 3 How to Repair a Painting Frame, How to Repair a Painting Frame: étape 1, image 2 de 3 How to Repair a Painting Frame, How to Repair a Painting Frame: étape 1, image 3 de 3
    • Wipe the frame with a damp cloth.
  2. How to Repair a Painting Frame: étape 2, image 1 de 1
    • Use a paper plate to mix the epoxy adhesives with a wooden stick.
    • Follow the instructions on your specific package of epoxy adhesive.
    • Make sure to use the glue within 45 minutes after mixing.
  3. How to Repair a Painting Frame: étape 3, image 1 de 1
    • Flip the glass painting and remove the frame joints.
  4. How to Repair a Painting Frame: étape 4, image 1 de 3 How to Repair a Painting Frame: étape 4, image 2 de 3 How to Repair a Painting Frame: étape 4, image 3 de 3
    • Use a wooden stick to apply a thin layer of glue on the edges of the frame.
  5. How to Repair a Painting Frame: étape 5, image 1 de 3 How to Repair a Painting Frame: étape 5, image 2 de 3 How to Repair a Painting Frame: étape 5, image 3 de 3
    • Put the glass painting over the glue and close the frame's metal clamps.
  6. How to Repair a Painting Frame: étape 6, image 1 de 1
    • Seal the clamps with duct tape for protection.
    • Repeat Steps 5-7 on all sides of the painting. It is suggested to place painting over the surface so it will be easier to apply the glue.
    • Once all four sides are done, clamp the corners with safety tape.
    • Let the glue dry for a minimum of 24 hours.
  7. How to Repair a Painting Frame: étape 7, image 1 de 2 How to Repair a Painting Frame: étape 7, image 2 de 2
    • Remove all the tape from the metal clamps and the corners of the frame.
  8. How to Repair a Painting Frame: étape 8, image 1 de 1
    • After that, you will have a restored painting frame.
Ligne d'arrivée
Sofia Morales
Membre depuis le 10/06/21
157 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 19
Total : 428
