Aller au contenu principal
How to Repair the Lining of a Canvas Shoe with an Iron-On Patch
Ce dont vous avez besoin
  1. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch, How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: étape 1, image 1 de 1
    • Identify the hole or tear in your canvas shoe.
  2. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: étape 2, image 1 de 2 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: étape 2, image 2 de 2
    • Preheat the iron to the highest setting without steam. In most cases this will be the cotton or linen setting.
    • If your iron does not have an on/off setting for steam, make sure there is no water in the water compartment when starting the project.
    • Always exercise caution when working around a hot iron.
  3. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: étape 3, image 1 de 3 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: étape 3, image 2 de 3 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: étape 3, image 3 de 3
    • Unlace the shoe so you can reach the hole better.
  4. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: étape 4, image 1 de 2 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: étape 4, image 2 de 2
    • Cut away loose threads and frayed edges to leave a smooth surface for the patch to adhere to.
  5. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: étape 5, image 1 de 3 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: étape 5, image 2 de 3 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: étape 5, image 3 de 3
    • Measure and cut patch to slightly larger than the size of the hole, this can be eye-balled.
  6. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: étape 6, image 1 de 2 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: étape 6, image 2 de 2
    • Lay a towel down to protect your work surface while ironing.
  7. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: étape 7, image 1 de 2 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: étape 7, image 2 de 2
    • Make sure the patch is as flat as possible against the shoe.
    • Iron over the patch for 60 seconds.
    • If you see or smell any smoke, stop ironing immediately. Your iron may be too hot.
  8. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: étape 8, image 1 de 1
    • Roll your towel tightly so it will fit inside your shoe.
  9. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: étape 9, image 1 de 3 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: étape 9, image 2 de 3 How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: étape 9, image 3 de 3
    • Use the rolled towel to support the shoe where you just ironed the patch.
    • Iron the location of the patch from the other side for 30 seconds.
  10. How to Repair the Lining of a Canvas Shoe with an Iron-On Patch: étape 10, image 1 de 1
    • Let the patch cool before use.
Try on your shoe. If there are edges that are not flattened, iron on a lower heat for 30 seconds on those spots. Be careful not to heat the patch too much, as the glue on the patch could dry out. Once cooled, re-lace the shoe, and it will be ready to wear again!
If you desire extra security, you can reinforce your patch using this guide.
Abigail Lodge
Membre depuis le 02/02/23
181 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 4-3, Andersen Winter 2023 Membre de l'équipe UC Davis, Team 4-3, Andersen Winter 2023
UCD-ANDERSEN-W23S4G3
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 56
Total : 812
