Aller au contenu principal
How to Replace Big Berkey Water Filters
Ce dont vous avez besoin
  1. How to Replace Big Berkey Water Filters, Filters: étape 1, image 1 de 2 How to Replace Big Berkey Water Filters, Filters: étape 1, image 2 de 2
    • Take the top half of your Berkey off, and place it to the side of your work station.
  2. How to Replace Big Berkey Water Filters: étape 2, image 1 de 2 How to Replace Big Berkey Water Filters: étape 2, image 2 de 2
    • Unscrew the White Elements by twisting counterclockwise.
  3. How to Replace Big Berkey Water Filters: étape 3, image 1 de 3 How to Replace Big Berkey Water Filters: étape 3, image 2 de 3 How to Replace Big Berkey Water Filters: étape 3, image 3 de 3
    • Unscrew the Black Element filters by twisting the black washers counterclockwise.
    • Remove the filters from the top compartment.
  4. How to Replace Big Berkey Water Filters: étape 4, image 1 de 2 How to Replace Big Berkey Water Filters: étape 4, image 2 de 2
    • Clean both the top and bottom tank compartments with a sponge.
    • Make sure to scrub both compartments clean of any mineral build-up that may have accumulated.
  5. How to Replace Big Berkey Water Filters: étape 5, image 1 de 3 How to Replace Big Berkey Water Filters: étape 5, image 2 de 3 How to Replace Big Berkey Water Filters: étape 5, image 3 de 3
    • Securely attach the priming tool to the Black Elements nozzle.
    • Push the filter nozzle against the tap for 10 seconds per filter to remove any impurities.
    • Run your sink water at a medium to slow flow-rate, to avoid water spraying everywhere.
  6. How to Replace Big Berkey Water Filters: étape 6, image 1 de 2 How to Replace Big Berkey Water Filters: étape 6, image 2 de 2
    • Leave equipment to air dry.
  7. How to Replace Big Berkey Water Filters: étape 7, image 1 de 3 How to Replace Big Berkey Water Filters: étape 7, image 2 de 3 How to Replace Big Berkey Water Filters: étape 7, image 3 de 3
    • Place your new Black Element filters through the holes in the top compartment.
    • Continue to screw the washer around the nozzle to secure the Black Element in place.
  8. How to Replace Big Berkey Water Filters: étape 8, image 1 de 3 How to Replace Big Berkey Water Filters: étape 8, image 2 de 3 How to Replace Big Berkey Water Filters: étape 8, image 3 de 3
    • Screw our new White Element filters over the nozzle of the Black Element filters, and repeat to attach all pieces securely.
  9. How to Replace Big Berkey Water Filters: étape 9, image 1 de 1
    • Enjoy your clean and purified drinking water from your Big Berkey for years to come.
Shannon Cash
Membre depuis le 03/03/23
169 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 18
30 derniers jours : 55
Total : 536
