Aller au contenu principal
How to Replace Field Hockey Stick Grip Tape
Ce dont vous avez besoin
  1. How to Replace Field Hockey Stick Grip Tape, Grip Tape: étape 1, image 1 de 3 How to Replace Field Hockey Stick Grip Tape, Grip Tape: étape 1, image 2 de 3 How to Replace Field Hockey Stick Grip Tape, Grip Tape: étape 1, image 3 de 3
    • Use a cloth and an anti-bacterial spray to clean the Field Hockey stick.
  2. How to Replace Field Hockey Stick Grip Tape: étape 2, image 1 de 3 How to Replace Field Hockey Stick Grip Tape: étape 2, image 2 de 3 How to Replace Field Hockey Stick Grip Tape: étape 2, image 3 de 3
    • Unravel the old sticky tape starting from the top of the stick.
  3. How to Replace Field Hockey Stick Grip Tape: étape 3, image 1 de 3 How to Replace Field Hockey Stick Grip Tape: étape 3, image 2 de 3 How to Replace Field Hockey Stick Grip Tape: étape 3, image 3 de 3
    • Unravel old tape until it meets the end of the handle.
  4. How to Replace Field Hockey Stick Grip Tape: étape 4, image 1 de 2 How to Replace Field Hockey Stick Grip Tape: étape 4, image 2 de 2
    • Carefully cut the tape so that end of grip tape below can be taken off.
    • Handle scissors with care never holding the open blade.
  5. How to Replace Field Hockey Stick Grip Tape: étape 5, image 1 de 3 How to Replace Field Hockey Stick Grip Tape: étape 5, image 2 de 3 How to Replace Field Hockey Stick Grip Tape: étape 5, image 3 de 3
    • Unravel the old grip tape from the top of the stick that spirals down.
    • Stop unravelling once loose-end cap is exposed fully.
  6. How to Replace Field Hockey Stick Grip Tape: étape 6, image 1 de 2 How to Replace Field Hockey Stick Grip Tape: étape 6, image 2 de 2
    • Put glue around the circumference of the base of the loose cap.
    • Line up and press the cap back onto the stick.
    • Handle glue with care so as not to spill.
  7. How to Replace Field Hockey Stick Grip Tape: étape 7, image 1 de 1
    • Let the glue dry for at least 10 minutes.
  8. How to Replace Field Hockey Stick Grip Tape: étape 8, image 1 de 3 How to Replace Field Hockey Stick Grip Tape: étape 8, image 2 de 3 How to Replace Field Hockey Stick Grip Tape: étape 8, image 3 de 3
    • Using new gauze tape, re-wrap the stick applying pressure in an upwards motion.
  9. How to Replace Field Hockey Stick Grip Tape: étape 9, image 1 de 2 How to Replace Field Hockey Stick Grip Tape: étape 9, image 2 de 2
    • Once new gauze covers the handle, cut the tape from its source.
  10. How to Replace Field Hockey Stick Grip Tape: étape 10, image 1 de 3 How to Replace Field Hockey Stick Grip Tape: étape 10, image 2 de 3 How to Replace Field Hockey Stick Grip Tape: étape 10, image 3 de 3
    • Secure the gauze with sticky tape at the top of the handle.
    • Cut the sticky tape from its source before wrapping around the top of the handle.
  11. How to Replace Field Hockey Stick Grip Tape: étape 11, image 1 de 3 How to Replace Field Hockey Stick Grip Tape: étape 11, image 2 de 3 How to Replace Field Hockey Stick Grip Tape: étape 11, image 3 de 3
    • Secure the gauze with sticky tape at the bottom of the handle.
    • Cut the sticky tape from its source before wrapping around the bottom of the handle.
  12. How to Replace Field Hockey Stick Grip Tape: étape 12, image 1 de 1
    • Enjoy your new grip tape!
Ligne d'arrivée
Sophia Juan
Membre depuis le 02/01/24
205 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 1-5, Andersen Winter 2024 Membre de l'équipe UC Davis, Team 1-5, Andersen Winter 2024
UCD-ANDERSEN-W24S1G5
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 14
Total : 110
