Aller au contenu principal
How to Replace T-fal Avante T24-B Toaster Lever
Ce dont vous avez besoin
  1. How to Replace T-fal Avante T24-B Toaster Lever, T-fal Avante T24-B Toaster Lever: étape 1, image 1 de 1
    • Make sure the toaster is unplugged before beginning.
  2. How to Replace T-fal Avante T24-B Toaster Lever: étape 2, image 1 de 3 How to Replace T-fal Avante T24-B Toaster Lever: étape 2, image 2 de 3 How to Replace T-fal Avante T24-B Toaster Lever: étape 2, image 3 de 3
    • Remove the snap-on buttons from the front of the toaster.
    • They can be removed by pulling with your hands or gently prying with a flat tool.
  3. How to Replace T-fal Avante T24-B Toaster Lever: étape 3, image 1 de 3 How to Replace T-fal Avante T24-B Toaster Lever: étape 3, image 2 de 3 How to Replace T-fal Avante T24-B Toaster Lever: étape 3, image 3 de 3
    • Flip the toaster so that you can see its underside.
    • Remove the seven 20 mm Torx T3 screws from the bottom of the toaster.
  4. How to Replace T-fal Avante T24-B Toaster Lever: étape 4, image 1 de 2 How to Replace T-fal Avante T24-B Toaster Lever: étape 4, image 2 de 2
    • Turn the toaster so that you can access the back of the toaster
    • Remove the 3 15 mm Torx T3 screws from the back of the toaster.
  5. How to Replace T-fal Avante T24-B Toaster Lever: étape 5, image 1 de 2 How to Replace T-fal Avante T24-B Toaster Lever: étape 5, image 2 de 2
    • Pull off the toaster casing.
  6. How to Replace T-fal Avante T24-B Toaster Lever: étape 6, image 1 de 2 How to Replace T-fal Avante T24-B Toaster Lever: étape 6, image 2 de 2
    • Unplug the casing so that it does not get in your way.
    • Unplug both wires connecting the casing to the internals of the toaster.
  7. How to Replace T-fal Avante T24-B Toaster Lever: étape 7, image 1 de 3 How to Replace T-fal Avante T24-B Toaster Lever: étape 7, image 2 de 3 How to Replace T-fal Avante T24-B Toaster Lever: étape 7, image 3 de 3
    • Pry both sides of the broken lever at the front of the toaster away and remove it.
  8. How to Replace T-fal Avante T24-B Toaster Lever: étape 8, image 1 de 3 How to Replace T-fal Avante T24-B Toaster Lever: étape 8, image 2 de 3 How to Replace T-fal Avante T24-B Toaster Lever: étape 8, image 3 de 3
    • Snap the replacement lever into place.
    • Attach one side first, then snap the other side on to fully attach the lever.
Cameron Johnson
Membre depuis le 01/16/23
157 Réputation
1 tutoriel rédigé
Équipe
York University, Team O-6, Woodhouse Winter 2023 Membre de l'équipe York University, Team O-6, Woodhouse Winter 2023
YORK-WOODHOUSE-W23SOG6
1 membre
1 tutoriel rédigé
2 commentaires
Thank you so much!
S J - Réponse
where do you get the replacement lever ?
Francois Rehel - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 34
Total : 523
