Aller au contenu principal
How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass
Ce dont vous avez besoin
  1. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass, Tuning Key: étape 1, image 1 de 3 How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass, Tuning Key: étape 1, image 2 de 3 How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass, Tuning Key: étape 1, image 3 de 3
    • Turn the tuning key counter-clockwise to the loosen string.
    • Only loosen the turning key(s) that need to be replaced.
    • Continue turning until there is slack in the string.
  2. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: étape 2, image 1 de 2 How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: étape 2, image 2 de 2
    • Cut the desired string with needle nose pliers.
    • Make sure the string has slack before cutting.
    • Remove the string by threading out through the bottom of the bass.
  3. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: étape 3, image 1 de 2 How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: étape 3, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the four 9.53 mm screws.
    • Remove the broken tuning key.
  4. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: étape 4, image 1 de 3 How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: étape 4, image 2 de 3 How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: étape 4, image 3 de 3
    • Adjust the direction of the replacement tuning key as need.
    • Line up the screw holes of the tuning key to the existing drill holes on the bass.
  5. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: étape 5, image 1 de 2 How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: étape 5, image 2 de 2
    • Note the length of the tuning key securing screws to estimate the drill depth needed to drill into the headstock.
    • Drill new placement holes into the headstock using a 1/16" drill bit.
    • Drill in a level environment and be aware of surroundings.
    • Drill the holes straight down and centered with the tuning key screw holes.
  6. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: étape 6, image 1 de 2 How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: étape 6, image 2 de 2
    • Secure the four 9.58 mm screws using a drill with the Phillips #2 screwdriver bit.
    • Make sure the drill is not held at an angle to prevent the screws from stripping.
  7. How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: étape 7, image 1 de 3 How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: étape 7, image 2 de 3 How to Replace a Tuning Key on a Sterling by Music Man StingRay Ray4HH Electric Bass: étape 7, image 3 de 3
    • Thread the string through the bottom of the bass to the new tuning key.
    • Loop the string around the tuning peg-three to four times-until tight.
    • Check for tension in the string.
    • Adjust the tuning key as needed.
This guide will work for any of the tuning keys on a Sterling by Music Man StingRay.
Darby Eime
Membre depuis le 02/13/23
145 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 30
Total : 315
