Aller au contenu principal
How to Replace the Pom Pom on a Beanie
Ce dont vous avez besoin
  1. How to Replace the Pom Pom on a Beanie, Beanie Pom Pom: étape 1, image 1 de 1
    • Use sewing scissors to cut the string that attaches the pom pom to the beanie if it's still loosely attached.
  2. How to Replace the Pom Pom on a Beanie: étape 2, image 1 de 2 How to Replace the Pom Pom on a Beanie: étape 2, image 2 de 2
    • Measure 10 inches of yarn.
    • Use your scissors to cut the yarn.
  3. How to Replace the Pom Pom on a Beanie: étape 3, image 1 de 3 How to Replace the Pom Pom on a Beanie: étape 3, image 2 de 3 How to Replace the Pom Pom on a Beanie: étape 3, image 3 de 3
    • Pull one end of the yarn through the eye of a hand sewing needle until you have an even amount of yarn on both sides of the needle.
    • The point of the needle is sharp enough to pierce skin.
  4. How to Replace the Pom Pom on a Beanie: étape 4, image 1 de 3 How to Replace the Pom Pom on a Beanie: étape 4, image 2 de 3 How to Replace the Pom Pom on a Beanie: étape 4, image 3 de 3
    • Push the needle through the pom pom, leaving a 3 inch tail of yarn.
    • Be aware of where the needle will exit and where your hand is holding the pom pom.
  5. How to Replace the Pom Pom on a Beanie: étape 5, image 1 de 3 How to Replace the Pom Pom on a Beanie: étape 5, image 2 de 3 How to Replace the Pom Pom on a Beanie: étape 5, image 3 de 3
    • Poke the pom pom with the point of the needle at the same place you poked it in Step 4.
    • Pull the needle all the way through and keep the yarn on the needle.
    • You will end up with two strands of yarn, one on each side of the pom pom.
  6. How to Replace the Pom Pom on a Beanie: étape 6, image 1 de 3 How to Replace the Pom Pom on a Beanie: étape 6, image 2 de 3 How to Replace the Pom Pom on a Beanie: étape 6, image 3 de 3
    • Push the needle through the top of the beanie.
    • Pull the needle all the way through until the pom pom is fixed against the beanie.
  7. How to Replace the Pom Pom on a Beanie: étape 7, image 1 de 3 How to Replace the Pom Pom on a Beanie: étape 7, image 2 de 3 How to Replace the Pom Pom on a Beanie: étape 7, image 3 de 3
    • Push the needle all the way through one of the holes of the button.
    • Keep button in place and remove the needle from the yarn.
  8. How to Replace the Pom Pom on a Beanie: étape 8, image 1 de 3 How to Replace the Pom Pom on a Beanie: étape 8, image 2 de 3 How to Replace the Pom Pom on a Beanie: étape 8, image 3 de 3
    • Put the second strand of yarn through the eye of the needle.
    • Poke the needle through the top of the beanie again.
    • Pull the remaining yarn all the way through to the other side of the beanie.
  9. How to Replace the Pom Pom on a Beanie: étape 9, image 1 de 3 How to Replace the Pom Pom on a Beanie: étape 9, image 2 de 3 How to Replace the Pom Pom on a Beanie: étape 9, image 3 de 3
    • Pull the yarn all the way through another hole in the button.
  10. How to Replace the Pom Pom on a Beanie: étape 11, image 1 de 2 How to Replace the Pom Pom on a Beanie: étape 11, image 2 de 2
    • Tie another overhand knot.
  11. How to Replace the Pom Pom on a Beanie: étape 12, image 1 de 2 How to Replace the Pom Pom on a Beanie: étape 12, image 2 de 2
    • Cut off the remaining ends of the yarn, cutting close to the button.
Ligne d'arrivée
Erin Shea
Membre depuis le 01/26/23
205 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 2-4, Morris Winter 2023 Membre de l'équipe UC Davis, Team 2-4, Morris Winter 2023
UCD-MORRIS-W23S2G4
2 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 17
30 derniers jours : 49
Total : 846
