Aller au contenu principal
How to Replace the Strings on your Rogue RM-100A A-Style Mandolin
Ce dont vous avez besoin
  1. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin, Strings: étape 1, image 1 de 2 How to Replace the Strings on your Rogue RM-100A A-Style Mandolin, Strings: étape 1, image 2 de 2
    • Lay the Mandolin face up on a flat surface.
    • Start at the headstock of the Mandolin, and unwind the wire string by turning the tuning peg in a clockwise rotation until it becomes loose and easy to remove.
  2. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: étape 2, image 1 de 3 How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: étape 2, image 2 de 3 How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: étape 2, image 3 de 3
    • At the tailpiece of the Mandolin, use both of your thumbs to apply pressure to push the tailpiece cover away from you.
    • The edge of the tailpiece is a bit sharp. If your fingers hurt, use a small towel or cloth to cushion your thumbs as you push.
  3. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: étape 3, image 1 de 2 How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: étape 3, image 2 de 2
    • Remove the string you are replacing from the tailpiece.
    • The string should be easy to remove.
  4. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: étape 4, image 1 de 2 How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: étape 4, image 2 de 2
    • Insert the new string loop onto the hook.
    • Pull the string up along the bridge onto the fretboard until it reaches the headstock.
  5. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: étape 5, image 1 de 2 How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: étape 5, image 2 de 2
    • Insert the string into the hole of the tuning post all the way through.
  6. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: étape 6, image 1 de 3 How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: étape 6, image 2 de 3 How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: étape 6, image 3 de 3
    • Loosen the hold of the string.
    • Turn the excess string to the left and pull it under the string.
    • Again, pull the excess string up and over to the left.
    • This creates a sort of hold/knot on the string.
  7. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: étape 7, image 1 de 3 How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: étape 7, image 2 de 3 How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: étape 7, image 3 de 3
    • Pull the knot.
    • Twist the tuning pegs in a counterclockwise rotation.
    • Twist towards the tailpiece.
  8. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: étape 8, image 1 de 1
    • Cut any excess string with pliers.
  9. How to Replace the Strings on your Rogue RM-100A A-Style Mandolin: étape 9, image 1 de 1
    • Place the tailpiece back by sliding it towards the headstock.
Carla Belen Castillo
Membre depuis le 08/29/23
169 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 26
Total : 203
