Aller au contenu principal
How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard
Ce dont vous avez besoin
  1. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard, How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: étape 1, image 1 de 1
    • Unplug the computer from the power supply before disassembly.
    • Wait 5 minutes after the device has been powered off.
  2. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: étape 2, image 1 de 3 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: étape 2, image 2 de 3 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: étape 2, image 3 de 3
    • Using a Phillips #1 screwdriver, remove two screws that would grant access to inner components of your computer.
    • Remove the side panel of the computer tower to access the inner components. Slide the panel then lift it to safely remove it.
    • Removing the panel may be different for your computer.
  3. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: étape 3, image 1 de 3 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: étape 3, image 2 de 3 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: étape 3, image 3 de 3
    • Using the Phillips #1 screwdriver, remove the screw holding the graphics card (GPU) onto the motherboard.
    • Disconnect any power cables that may be attached to your graphics card.
    • Carefully slide the graphics card out from its slot.
  4. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: étape 4, image 1 de 2 How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: étape 4, image 2 de 2
    • Remove the CMOS Battery using a plastic opening tool.
    • There may be a spring mechanism available to use to easily remove the battery.
  5. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: étape 5, image 1 de 1
    • Wait 5 minutes to allow enough time for the power to cycle through.
  6. How to Reset a Gigabyte GA-Z97X-Gaming 5 Motherboard: étape 6, image 1 de 1
    • Insert battery back into position with the flat side facing upwards.
2 autres ont terminé cette réparation.
Andrew Barsoom
Membre depuis le 01/17/21
181 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G3, Melo-Thaiss Winter 2021 Membre de l'équipe York University, Team S1-G3, Melo-Thaiss Winter 2021
YORK-MELO-THAISS-W21S1G3
1 membre
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 29
30 derniers jours : 157
Total : 4,442
