Aller au contenu principal
How to extract a leaked battery from a pocket-torchlight
Ce dont vous avez besoin
  1. How to extract a  leaked battery from a pocket-torchlight, battery: étape 1, image 1 de 2 How to extract a  leaked battery from a pocket-torchlight, battery: étape 1, image 2 de 2
    • To successfully extract a cylindrical dry-cell (e.g. AAA , baby–cell) on which you have no mechanical purchase, and which is stuck in the case because of leaked electrolyte use a manual spiral drill. Drill it through the bottom of the battery to get a grip on it and retract it. Works ! Do not destroy the case by using excessive force.
To successfully extract a cylindrical dry-cell on which you have no mechanical purchase, and which is stuck in the case because of leaked electrolyte use a manual spiral drill.
Drill it through the bottom of the battery to get a grip on it and retract it. Works like a charm!
Counter the drill at the battery-case but NOT against the torch'es topside to avoid structural damage to the torchlight.
2 autres ont terminé cette réparation.
ein Stein
Membre depuis le 12/07/20
204 Réputation
1 tutoriel rédigé
7 commentaires
works like a charm! there is no better way. obviously, the leaked battery is being destroyed in the process.
ein Stein - Réponse
works for aluminium € 30 “creed-light”
ein Stein - Réponse
getting the battery out is much easier than publishing a guide here. wow they make it complicated!
ein Stein - Réponse
don’t forget to scratch off any insulating rust caused by the electrolyte on the battery–contacts of the torchlight.
ein Stein - Réponse
fragile plastic torches may not withstand the force required to drill, breaking the torch.
unless you have a strong magnet to pull the battery, it is unfortunate.
ein Stein - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 46
Total : 884
