Aller au contenu principal
How to reset watch hands
Ce dont vous avez besoin
  1. How to reset watch hands, How to reset watch hands: étape 1, image 1 de 2 How to reset watch hands, How to reset watch hands: étape 1, image 2 de 2
    • To make your watch easier to work with, start by taking off the straps.
    • Pull down the strap until the lug can be accessed.
    • Pull down on the lug and it should freely come out of place.
    • The lugs have springs in them so when removing, be careful not to let them fly out of your work space.
  2. How to reset watch hands: étape 2, image 1 de 3 How to reset watch hands: étape 2, image 2 de 3 How to reset watch hands: étape 2, image 3 de 3
    • Locate the divot on the underside of the watch.
    • Carefully place your thin blade in the divot and pop the buckle off of your watch.
  3. How to reset watch hands: étape 3, image 1 de 2 How to reset watch hands: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use your tweezers to grab onto the plastic holder and gently pull it out.
  4. How to reset watch hands: étape 4, image 1 de 2 How to reset watch hands: étape 4, image 2 de 2
    • Apply pressure with the pointed tip instrument at the spot circled; around where the stem meets the main part of the watch.
    • While applying pressure, pull the stem out and it should freely come off.
  5. How to reset watch hands: étape 5, image 1 de 2 How to reset watch hands: étape 5, image 2 de 2
    • Gently place the tweezers underneath the hands of your watch.
    • To remove the hands, carefully pry upwards and all of the hands should pop off.
    • In order to not accidentally scratch the face of your watch, place a piece of paper under where you will be prying up the hands.
  6. How to reset watch hands: étape 6, image 1 de 2 How to reset watch hands: étape 6, image 2 de 2
    • Using your tweezers place the hour hand in the center of the watch.
    • Press down on the hand, so that the hour hand is firmly attached to the center post.
    • Align the hour hand with the 3 O'clock position on your watch.
    • Be careful handling the hands because they can be very fragile.
  7. How to reset watch hands: étape 7, image 1 de 2 How to reset watch hands: étape 7, image 2 de 2
    • Using your tweezers again, place the minute hand in the center of the face.
    • Align the minute hand with the 12 O'clock position.
    • Press down on the hand until the minute hand is firmly in place.
    • Look to make sure there is a small amount of space between the hour hand and the face, as well as between the minute hand and the face.
  8. How to reset watch hands: étape 8, image 1 de 1
    • Carefully pick up and place the second hand in the center of the watch.
    • Press down firmly so that the second hand stays in place.
    • The position of the second hand is not extremely important, but to get the most accuracy; place it in line with the minute hand.
21 autres ont terminé cette réparation.
Jayze Crawford
Membre depuis le 09/29/15
735 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 17-2, Green Fall 2015 Membre de l'équipe Cal Poly, Team 17-2, Green Fall 2015
CPSU-GREEN-F15S17G2
4 membres
8 tutoriels rédigés
6 commentaires
The hands on my clock doesn't work
Aaliyah Crittenden - Réponse
There could be any number of reasons for that. You could adapt this method to fix clock hands that weren’t in alignment, but it won’t help you if they just aren’t moving…
Fin Hirschoff -
Thanks - the second hand fell off of my kid’s lego watch. It still worked, but it was important to him that the second hand moved. The trick in step 4 to get the stem off was the crucial thing that I was missing.
dunhamsteve - Réponse
I’m using Seiko Sportura ,and i love its kinetic movement.I just recommend this watch.
joseph john - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 20
7 derniers jours : 112
30 derniers jours : 406
Total : 83,226
