Aller au contenu principal
Kindle 7th Generation Battery Replacement
Ce dont vous avez besoin
  1. Kindle 7th Generation Battery Replacement, Front Panel: étape 1, image 1 de 2 Kindle 7th Generation Battery Replacement, Front Panel: étape 1, image 2 de 2
    • Power off your Kindle before beginning disassembly.
    • At each corner, use the blue plastic opening tool to unhook and separate the front panel from the adhesive.
    • Run the tool along the seams to pry open the front panel.
  2. Kindle 7th Generation Battery Replacement: étape 2, image 1 de 1
    • Peel the front panel off to remove it from the Kindle.
    • If this is the first time the front panel has been removed, the adhesive may require a significant amount of force to undo.
    • To prevent damaging the front panel, peel the panel from the corners towards the middle of the Kindle.
    • When reassembling your device, if you are replacing the front panel, additional adhesive may be required.
  3. Kindle 7th Generation Battery Replacement, Back Panel: étape 3, image 1 de 2 Kindle 7th Generation Battery Replacement, Back Panel: étape 3, image 2 de 2
    • Remove the ten 5.0 mm T5 Torx screws.
    • A magnetized screw mat can help you keep track of your screws.
  4. Kindle 7th Generation Battery Replacement: étape 4, image 1 de 1
    • Working evenly along the corners and edges, separate the internal contents from the back panel.
    • There are many clips securing the screen to the back panel. Force will be required to remove the back, but you should never feel that the Kindle may break.
  5. Kindle 7th Generation Battery Replacement, Battery: étape 5, image 1 de 1
    • Flip the Kindle over, exposing the battery and motherboard.
  6. Kindle 7th Generation Battery Replacement: étape 6, image 1 de 2 Kindle 7th Generation Battery Replacement: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use the blunted precision tweezers to pinch the ends of the clip securing the battery cord to the motherboard.
    • Gently slide the cord from the motherboard connection.
  7. Kindle 7th Generation Battery Replacement: étape 7, image 1 de 2 Kindle 7th Generation Battery Replacement: étape 7, image 2 de 2
    • Use the plastic opening tool to pry the battery from the backside of the screen.
    • Set the battery aside.
    • The battery has excessive adhesive so this may take some extra effort.
    • If replacing your battery, safely dispose of your damaged battery and use adhesive to insert the new battery.
24 autres ont terminé cette réparation.
Abby Roulier
Membre depuis le 02/08/15
966 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 6-28, Amido Winter 2015 Membre de l'équipe Cal Poly, Team 6-28, Amido Winter 2015
CPSU-AMIDO-W15S6G28
4 membres
18 tutoriels rédigés
16 commentaires
Where can I purchase the battery?
Boon - Réponse
Fairly easy to do. Saves a lot of money compared to buying a whole new Kindle :) Thank you for this! A note: I've never seen batteries as...soft as these. Take care when using the removal tool. I could be easy to puncture the battery which could cause a big mess and possibly injury.
Joshua - Réponse
Where do I get a new battery from please?
Tracy Armstrong - Réponse
The link to buy a replacement battery on amazon is dead. Ideas on an alternate source?
Yagoth - Réponse
You can get the batteries on Ebay.
Mike Rayner - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 27
7 derniers jours : 215
30 derniers jours : 933
Total : 38,742
