Aller au contenu principal
Kindle Paperwhite 1st Generation Case Replacement
Ce dont vous avez besoin
  1. Kindle Paperwhite 1st Generation Case Replacement, Case: étape 1, image 1 de 2 Kindle Paperwhite 1st Generation Case Replacement, Case: étape 1, image 2 de 2
    • Using a spudger or plastic opening tool, gently pry the bezel from the screen. It is easier to start in the corners and work your way around the bezel.
    • Do not insert the spudger too far under the bezel; it could easily damage the screen.
  2. Kindle Paperwhite 1st Generation Case Replacement: étape 2, image 1 de 3 Kindle Paperwhite 1st Generation Case Replacement: étape 2, image 2 de 3 Kindle Paperwhite 1st Generation Case Replacement: étape 2, image 3 de 3
    • Remove the eleven 3.0 mm Phillips screws surrounding the midframe.
    • At the top of the display, a strip of black tape covers one screw.
  3. Kindle Paperwhite 1st Generation Case Replacement: étape 3, image 1 de 1
    • Lift the midframe out of the case.
    • If the midframe is stuck, slide it to the left first, and then lift it out.
2 autres ont terminé cette réparation.
Anthony Nahal
Membre depuis le 01/25/13
60 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 3-33, Amido Winter 2013 Membre de l'équipe Cal Poly, Team 3-33, Amido Winter 2013
CPSU-AMIDO-W13S3G33
4 membres
17 tutoriels rédigés
2 commentaires
Thanks for the guide but do you know anywhere can we get a replacement case?
jerryw - Réponse
4 years too late but I found this
Pao-Tang Kao - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 13
30 derniers jours : 63
Total : 9,297
