Aller au contenu principal
Kindle Paperwhite 2nd Generation Screen Replacement
Ce dont vous avez besoin
  1. Kindle Paperwhite 2nd Generation Screen Replacement, Screen: étape 1, image 1 de 1
    • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
    • Be sure to begin prying along the edges, these are the optimal points for removing the bezel.
  2. Kindle Paperwhite 2nd Generation Screen Replacement: étape 2, image 1 de 2 Kindle Paperwhite 2nd Generation Screen Replacement: étape 2, image 2 de 2
    • Remove the eleven 3.2 mm Phillips 000 screws from corners of mid-frame and from behind the black strip as shown.
    • Do not forget the screw in the middle of the black adhesive strip.
  3. Kindle Paperwhite 2nd Generation Screen Replacement: étape 3, image 1 de 1
    • Carefully lift and remove the mid-frame.
  4. Kindle Paperwhite 2nd Generation Screen Replacement: étape 4, image 1 de 1
    • The screen itself is glued to the mid-frame. If your replacement screen does not include the mid-frame, heat the screen with an iOpener and gently pry it from the mid-frame with a blue plastic opening tool.
5 autres ont terminé cette réparation.
Tyler Davis
Membre depuis le 09/15/16
1 574 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 11-2, Blackwell Fall 2016 Membre de l'équipe USF Tampa, Team 11-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G2
4 membres
7 tutoriels rédigés
2 commentaires
My opening tool is orange. Will this still work for me?
FoxRunTime - Réponse
I’m hoping to replace my screen with this part:
Kindle Paperwhite (2nd Gen) Display
Does this part include the mid-frame? I would like to avoid using the iOpener if possible.
Thank you!
Liam Cahill - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 25
30 derniers jours : 104
Total : 11,800
