Aller au contenu principal
Lighting: Replacing Light Emitting Diode
Ce dont vous avez besoin
  1. Lighting: Replacing Light Emitting Diode, Light Emitting Diode: étape 1, image 1 de 1
    • Using a plastic opening tool, remove the base of the Light Angel.
    • Insert the plastic opening tool between the base and the LED housing and pull outwards on the handle.
  2. Lighting: Replacing Light Emitting Diode: étape 2, image 1 de 1
    • Using a Phillips head jeweler's screwdriver, remove the screw on the battery housing.
    • To remove the screw, turn counterclockwise.
    • Remember to put all the screws you take out somewhere safe so you can find them when it's time to reassemble the light.
  3. Lighting: Replacing Light Emitting Diode: étape 3, image 1 de 1
    • Remove and set aside the (4) AA batteries in the battery housing.
  4. Lighting: Replacing Light Emitting Diode: étape 4, image 1 de 1
    • Using a Phillips head jeweler's screwdriver, remove the (6) screws holding the LED housing together.
    • To remove the screws, turn counterclockwise.
  5. Lighting: Replacing Light Emitting Diode: étape 5, image 1 de 1
    • Insert the plastic opening tool into the crease on the side of the LED housing to separate it from the rest of the device.
  6. Lighting: Replacing Light Emitting Diode: étape 6, image 1 de 1
    • Locate the faulty light emitting diode on the back of the circuit board.
    • Using a soldering iron and desoldering braid, unsolder the connection on the light emitting diode.
    • Do not allow the soldering iron to come in contact with other components on the circuit board.
    • For detailed instructions on how to solder go to Comment souder et dessouder des connexions
  7. Lighting: Replacing Light Emitting Diode: étape 7, image 1 de 1
    • Insert the new light emitting diode through the two holes left from removing the old one.
    • Note: the picture is not of the Light Angel circuit board. It is a general example of inserting a light emitting diode on a circuit board. Photo Credit: Comment souder et dessouder des connexions
  8. Lighting: Replacing Light Emitting Diode: étape 8, image 1 de 1
    • Using solder and a soldering iron, solder the new LED to the circuit board.
    • Keep your solder joints separate to avoid short circuiting the circuit board.
2 autres ont terminé cette réparation.
Matthew Corigliano
Membre depuis le 02/10/16
155 Réputation
1 tutoriel rédigé
Équipe
Colorado Springs, Team 8-6, Mcmichael Spring 2016 Membre de l'équipe Colorado Springs, Team 8-6, Mcmichael Spring 2016
UCCS-MCMICHAEL-S16S8G6
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 17
30 derniers jours : 43
Total : 4,768
