Aller au contenu principal
MSI Modern 15 A10M-242 15.6 RAM Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. MSI Modern 15 A10M-242 15.6 RAM Replacement, Preparing the laptop for opening: étape 1, image 1 de 3 MSI Modern 15 A10M-242 15.6 RAM Replacement, Preparing the laptop for opening: étape 1, image 2 de 3 MSI Modern 15 A10M-242 15.6 RAM Replacement, Preparing the laptop for opening: étape 1, image 3 de 3
    • Turn off your laptop.
    • Unplug your power adapter.
    • Remove any USB devices that you have connected to your laptop.
    • Close your laptop.
  2. MSI Modern 15 A10M-242 15.6 RAM Replacement, Hardware protection: étape 2, image 1 de 3 MSI Modern 15 A10M-242 15.6 RAM Replacement, Hardware protection: étape 2, image 2 de 3 MSI Modern 15 A10M-242 15.6 RAM Replacement, Hardware protection: étape 2, image 3 de 3
    • Turn your laptop 180 degrees.
    • Insert a safety pin in the "Reset EC" slot.
    • There is potential hardware damage to the laptop if "Reset EC" not performed.
    • A safety pin has small enough diameter to fit into the "Reset EC" to perform this step.
    • Resetting the EC requires holding the RESET EC button for a full 30 seconds. Simply inserting the safety pin for a brief moment will not trigger a reset.
    • After performing a reset of the EC, your PC may not turn on using the power button if it's on battery power. In this case, you'll need to plug in the charger and wait for the laptop to turn on and to display. This does indeed indicate that the RESET EC was successful.
    • Wait for 5 minutes after Resetting EC, to ensure that all components are properly powered down, which can prevent accidental damage.
  3. MSI Modern 15 A10M-242 15.6 RAM Replacement, Unscrewing the laptop: étape 3, image 1 de 2 MSI Modern 15 A10M-242 15.6 RAM Replacement, Unscrewing the laptop: étape 3, image 2 de 2
    • Remove eleven 1 mm screws using a Phillips #1 screwdriver.
    • Phillips #1 is known also as PH1 in some screwdrivers set
  4. MSI Modern 15 A10M-242 15.6 RAM Replacement, Removing the back cover: étape 4, image 1 de 3 MSI Modern 15 A10M-242 15.6 RAM Replacement, Removing the back cover: étape 4, image 2 de 3 MSI Modern 15 A10M-242 15.6 RAM Replacement, Removing the back cover: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    J'achète
    • Turn your laptop vertically, so the monitor base is facing up.
    • Before continuing this step, make sure you have unscrewed all 11 screws, including the one hidden under the "Factory Seal" sticker. Ignoring this may cause you to break the back cover of your laptop by missing a screw that prevents it from opening properly.
    • Insert the plastic card above the back cover plate along the spine and slide it through the side.
    • You will hear a popping sound as the card slides through the laptop. This is the plastic hinges unlocking as it slides through.
    • Warning: Use a plastic card or spudger to open your laptop back cover. Using metal or hard material for this step will likely cause severe damage to the laptop if you are not a professional.
    • Remove the back cover.
  5. MSI Modern 15 A10M-242 15.6 RAM Replacement, Disconnecting the battery: étape 5, image 1 de 3 MSI Modern 15 A10M-242 15.6 RAM Replacement, Disconnecting the battery: étape 5, image 2 de 3 MSI Modern 15 A10M-242 15.6 RAM Replacement, Disconnecting the battery: étape 5, image 3 de 3
    • Unplug the battery cable connected to motherboard.
    • Failure to complete this step can result in electrical damage.
    • This requires some force to unplug the cable.
    • Hold the pin when unplugging the battery cable; pulling on the wires will cause damage to the battery cable.
  6. MSI Modern 15 A10M-242 15.6 RAM Replacement, Removing the RAM: étape 6, image 1 de 3 MSI Modern 15 A10M-242 15.6 RAM Replacement, Removing the RAM: étape 6, image 2 de 3 MSI Modern 15 A10M-242 15.6 RAM Replacement, Removing the RAM: étape 6, image 3 de 3
    • Place your fingers on side of the RAM slot.
    • Push your fingers down on the side of the slot to release the RAM.
    • Remove the RAM from the slot.
  7. MSI Modern 15 A10M-242 15.6 RAM Replacement, Inserting the RAM: étape 7, image 1 de 3 MSI Modern 15 A10M-242 15.6 RAM Replacement, Inserting the RAM: étape 7, image 2 de 3 MSI Modern 15 A10M-242 15.6 RAM Replacement, Inserting the RAM: étape 7, image 3 de 3
    • Line up the new RAM stick with the RAM slot.
    • Insert the RAM into the slot.
    • Press down on the RAM to lock it in place.
    • Press down firmly on the RAM. There will be a pop sound when the RAM is locked in place.
2 autres ont terminé cette réparation.
Brian M. Williams
Membre depuis le 09/28/21
175 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 22
30 derniers jours : 105
Total : 2,886
