Aller au contenu principal
MagLite 4D O-Ring Replacement
  1. MagLite 4D O-Ring Replacement, O-ring: étape 1, image 1 de 1
    • Unscrew the Maglite head.
    • Remember, to unscrew a flashlight head, turn it counterclockwise.
  2. MagLite 4D O-Ring Replacement: étape 2, image 1 de 1
    • Remove the lens.
  3. MagLite 4D O-Ring Replacement: étape 3, image 1 de 1
    • Remove the reflector cone.
  4. MagLite 4D O-Ring Replacement: étape 4, image 1 de 1
    • Examine the O-ring for damage.
    • The O-ring is the black rubber band around the flashlight head.
  5. MagLite 4D O-Ring Replacement: étape 5, image 1 de 1
    • Remove the damaged O-ring.
    • The O-ring is flexible, so it should be easy to pull off. Or, it may fall off if it is broken.
  6. MagLite 4D O-Ring Replacement: étape 6, image 1 de 1
    • Place the new O-ring in the same place as the original.
    • The O-ring is flexible, so simply pull it on gently.
  7. MagLite 4D O-Ring Replacement: étape 7, image 1 de 1
    • Wipe the moisture from the reflector cone with a paper towel or soft cloth.
  8. MagLite 4D O-Ring Replacement: étape 8, image 1 de 1
    • Wipe the moisture from the lens with a paper towel or soft cloth.
  9. MagLite 4D O-Ring Replacement: étape 9, image 1 de 1
    • Replace the reflector cone.
    • Replace the lens.
  10. MagLite 4D O-Ring Replacement: étape 10, image 1 de 1
    • Screw on the Maglite head.
    • Remember, to screw on a flashlight head, turn it clockwise.
  11. MagLite 4D O-Ring Replacement: étape 11, image 1 de 1
    • Test the Maglite by turning it on.
    • If your Maglite turns on, your work is complete!
If your Maglite turns on, it should be ready to go! If your Maglite does not turn on, the next step is to look at the battery compartment. Please see another guide for this step.
Laura Allen
Membre depuis le 10/04/21
223 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 32
Total : 612
