Aller au contenu principal
Medtronic 670G Battery Replacement
Ce dont vous avez besoin
  1. Medtronic 670G Battery Replacement, Battery: étape 1, image 1 de 2 Medtronic 670G Battery Replacement, Battery: étape 1, image 2 de 2
    • Detach the clip on the back of the device.
  2. Medtronic 670G Battery Replacement: étape 2, image 1 de 3 Medtronic 670G Battery Replacement: étape 2, image 2 de 3 Medtronic 670G Battery Replacement: étape 2, image 3 de 3
    • Place the small protrusion on the bottom of the clip into the slot on top of the battery housing, and turn it counter clockwise.
  3. Medtronic 670G Battery Replacement: étape 3, image 1 de 3 Medtronic 670G Battery Replacement: étape 3, image 2 de 3 Medtronic 670G Battery Replacement: étape 3, image 3 de 3
    • Remove the battery cap.
    • Dispose of the old battery according to your state guidelines.
  4. Medtronic 670G Battery Replacement: étape 4, image 1 de 2 Medtronic 670G Battery Replacement: étape 4, image 2 de 2
    • Insert the new battery, making sure the negative end (the flat part of the battery) is facing down.
  5. Medtronic 670G Battery Replacement: étape 5, image 1 de 3 Medtronic 670G Battery Replacement: étape 5, image 2 de 3 Medtronic 670G Battery Replacement: étape 5, image 3 de 3
    • Replace the battery cap tighten until it is aligned.
    • Do not over-tighten the cap as it will make it extremely difficult to unscrew next time.
  6. Medtronic 670G Battery Replacement: étape 6, image 1 de 1
    • Turn on the pump and wait until the HOME screen load to make sure the battery is working.
Your Medtronic 670G insulin pump is good-to-go!
2 autres ont terminé cette réparation.
2 commentaires
Hello,
It looks like the Medtronic 670G uses standard AA batteries. You should be able to find AA batteries at most grocery and hardware stores, or online here. We hope that helps!
Connor Bassolino -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 29
30 derniers jours : 95
Total : 1,550
