Aller au contenu principal
Oven Heating Element Replacement
Ce dont vous avez besoin
  1. Oven Heating Element Replacement, Element: étape 1, image 1 de 1
    • Before purchasing your replacement element, make sure it matches the size of the first element.
    • The element may not fit inside the stove if it is not the appropriate size.
  2. Oven Heating Element Replacement: étape 2, image 1 de 2 Oven Heating Element Replacement: étape 2, image 2 de 2
    • Go to your electrical panel and turn off the power to the stove.
    • WARNING: Do NOT attempt any of these next steps with the power on.
  3. Oven Heating Element Replacement: étape 3, image 1 de 2 Oven Heating Element Replacement: étape 3, image 2 de 2
    • Open the oven door and unscrew the 5 mm Robertson head screws that keep the element in place.
    • In most cases, there will be two or three screws to remove.
    • Make sure you check the screws thoroughly in case there are more.
  4. Oven Heating Element Replacement: étape 4, image 1 de 3 Oven Heating Element Replacement: étape 4, image 2 de 3 Oven Heating Element Replacement: étape 4, image 3 de 3
    • Using your voltmeter, place it on the two wires to make sure there is no electrical current.
    • Gently pull out the element two or three inches to expose the connecting wires.
  5. Oven Heating Element Replacement: étape 5, image 1 de 3 Oven Heating Element Replacement: étape 5, image 2 de 3 Oven Heating Element Replacement: étape 5, image 3 de 3
    • Mark down the coloured wires and how they are connected. You will need to match them by color when you reconnect the element.
    • It may be helpful to take a photo of the element with the wires still connected. This will make reconnecting it easier.
    • Remove the screws holding the wires in place.
  6. Oven Heating Element Replacement: étape 6, image 1 de 1
    • Remove the damaged element from the stove. It should slide out easily.
    • If possible, try to locate where the damage on the element took place for future reference.
    • Begin installing the new element.
  7. Oven Heating Element Replacement: étape 7, image 1 de 2 Oven Heating Element Replacement: étape 7, image 2 de 2
    • Connect the power wires by matching the same color as the original element. (Refer to Step 5 for more information.)
    • Gently re-insert the element back into the stove opening.
    • Refasten the two screws at the front to secure the element in place.
  8. Oven Heating Element Replacement: étape 8, image 1 de 1
    • Close the oven door and reset the power through the electrical panel.
  9. Oven Heating Element Replacement: étape 9, image 1 de 1
    • Turn the power on and turn the oven on to make sure the element is functioning properly.
    • There may be some smoke and an odor coming from the baking element because of the protective coating. This is normal.
Ligne d'arrivée
Alex Costantino
Membre depuis le 01/15/21
226 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G2, Woodhouse Winter 2021 Membre de l'équipe York University, Team S1-G2, Woodhouse Winter 2021
YORK-WOODHOUSE-W21S1G2
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 35
30 derniers jours : 173
Total : 2,809
