Aller au contenu principal
Peugeot Boxer Headlamp Bulb Replacement
Ce dont vous avez besoin
  1. Peugeot Boxer Headlamp Bulb Replacement, Bonnet Catch: étape 1, image 1 de 1
    • Open the passenger side door to find the bonnet release catch.
    • Pull the catch down and towards you to release the bonnet of the van.
  2. Peugeot Boxer Headlamp Bulb Replacement, Secondary Bonnet Catch: étape 2, image 1 de 1
    • Once the bonnet is loosened, find the yellow handle of the secondary bonnet catch by feeling underneath
    • Once you locate the catch, push the bonnet catch upwards, this will release the bonnet
  3. Peugeot Boxer Headlamp Bulb Replacement, Open Bonnet: étape 3, image 1 de 1
    • Use the strut, located to the right of the hood to prop open the bonnet.
    • Make sure the strut is secure to the hood! If the strut comes down, this may damage your car and strut!
  4. Peugeot Boxer Headlamp Bulb Replacement, Torx Bolts: étape 4, image 1 de 2 Peugeot Boxer Headlamp Bulb Replacement, Torx Bolts: étape 4, image 2 de 2
    • Remove the two Torx bolts holding the headlamp assembly at each corner.
  5. Peugeot Boxer Headlamp Bulb Replacement, Slide Headlamp Out: étape 5, image 1 de 1
    • Gently slide headlamp assembly out
    • Make sure to move the headlight diagonally towards you and towards the centre of the vehicle
  6. Peugeot Boxer Headlamp Bulb Replacement, Rubber Cap: étape 6, image 1 de 2 Peugeot Boxer Headlamp Bulb Replacement, Rubber Cap: étape 6, image 2 de 2
    • Pull the tab on rubber cap, revealing the back of the headlamp bulb.
  7. Peugeot Boxer Headlamp Bulb Replacement, Disconnect Bulb: étape 7, image 1 de 1
    • Remove the electrical connection from the old bulb (it should just pull off).
    • Make a note of which way up the plug was for when you connect everything back up again.
  8. Peugeot Boxer Headlamp Bulb Replacement, Remove Bulb: étape 8, image 1 de 1
    • With needle-nosed pliers, carefully 'wiggle' the old bulb out from its housing.
  9. Peugeot Boxer Headlamp Bulb Replacement, New Bulb: étape 9, image 1 de 1
    • Locate your new bulb. Taking care to make sure it is the right way up, push it firmly into place until you feel it clip in.
2 autres ont terminé cette réparation.
Kit Marsden
Membre depuis le 05/04/21
404 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 31
30 derniers jours : 138
Total : 4,169
