Aller au contenu principal
Propane Grill Regulator & Hose Replacement
Ce dont vous avez besoin
  1. Propane Grill Regulator & Hose Replacement, Battery, Regulator & Hose: étape 1, image 1 de 2 Propane Grill Regulator & Hose Replacement, Battery, Regulator & Hose: étape 1, image 2 de 2
    • Completely close the propane tank by turning the valve on the top clockwise. This prevents propane from leaking during the replacement.
    • Breathing in or swallowing propane can harm your health.
    • Turn the knob on the hose counter clockwise to disconnect it from the tank.
  2. Propane Grill Regulator & Hose Replacement: étape 2, image 1 de 2 Propane Grill Regulator & Hose Replacement: étape 2, image 2 de 2
    • Find the electric igniter on the grill and turn it counter clockwise to reveal one AA battery.
    • Replace the old battery with a new one.
  3. Propane Grill Regulator & Hose Replacement: étape 3, image 1 de 1
    • Locate the orifice that connects the base of the grill and the hose to one another.
    • An orifice is a valve commonly found on gas powered home products. This allows the gas to pass through from the source (i.e the propane tank) and burn properly.
    • Conncected to the orifice should be a nut. Use the crescent wrench to turn the nut counter clockwise and remove the hose from the base.
  4. Propane Grill Regulator & Hose Replacement: étape 4, image 1 de 2 Propane Grill Regulator & Hose Replacement: étape 4, image 2 de 2
    • Begin hand tightening the new hose to the nut that is connected to the orifice.
    • If you over tighten the bolt or do not hand tighten it first, you could cross thread the orifice and create more problems for the grill.
    • Once it has been adequately hand tightened use the crescent wrench to finish securing it to the orifice.
3 autres ont terminé cette réparation.
Evan Jureski
Membre depuis le 03/16/17
141 Réputation
1 tutoriel rédigé
Équipe
Missouri Western, Team S40-G12, Kunkel Spring 2017 Membre de l'équipe Missouri Western, Team S40-G12, Kunkel Spring 2017
MWSU-KUNKEL-S17S40G12
1 membre
2 tutoriels rédigés
2 commentaires
I have a Napoleon travel series P285Q X. Do I need to purchase a control valve with a hose to convert from a 1 - 20 lb tank?
Rob Fillion - Réponse
Question. Do I need to purchase a pressure valve and a hose to convert from a 1 lb to a 20 lb tank. The bbq is a Napoleon 285 pro series travel.
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 22
30 derniers jours : 97
Total : 6,296
