Aller au contenu principal
Replacing Oakley Flak 2 Lens and Rubber Kits
Ce dont vous avez besoin
  1. Replacing Oakley Flak 2 Lens and Rubber Kits, Lens & Rubber Kits: étape 1, image 1 de 3 Replacing Oakley Flak 2 Lens and Rubber Kits, Lens & Rubber Kits: étape 1, image 2 de 3 Replacing Oakley Flak 2 Lens and Rubber Kits, Lens & Rubber Kits: étape 1, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Pinch the tweezers and place them against the rubber ear socket.
    • Push the tweezers through the hole.
    • Slowly pull out the rubber ear sock.
    • Repeat the previous steps for the other side.
  2. Replacing Oakley Flak 2 Lens and Rubber Kits: étape 2, image 1 de 2 Replacing Oakley Flak 2 Lens and Rubber Kits: étape 2, image 2 de 2
    • Pull up on the bottom of the rubber nose pad.
    • Push the rubber nose pad up to remove it.
    • Repeat the steps for the other side.
  3. Replacing Oakley Flak 2 Lens and Rubber Kits: étape 3, image 1 de 2 Replacing Oakley Flak 2 Lens and Rubber Kits: étape 3, image 2 de 2
    • From the bridge of the glasses, push the bottom outer corner of the lens up.
    • Use the groove to slide the dislodged side of the lens down and out.
  4. Replacing Oakley Flak 2 Lens and Rubber Kits: étape 4, image 1 de 3 Replacing Oakley Flak 2 Lens and Rubber Kits: étape 4, image 2 de 3 Replacing Oakley Flak 2 Lens and Rubber Kits: étape 4, image 3 de 3
    • Make sure to match the correct ear sock to the correct temple side.
    • Insert the glasses temple in the rubber sock
    • Push/ Pull the rubber sock forward.
    • Push in the rubber tab into the hole near the hinge.
  5. Replacing Oakley Flak 2 Lens and Rubber Kits: étape 5, image 1 de 3 Replacing Oakley Flak 2 Lens and Rubber Kits: étape 5, image 2 de 3 Replacing Oakley Flak 2 Lens and Rubber Kits: étape 5, image 3 de 3
    • Insert the rubber nose pad from the top.
    • Stretch the nose pad at the bottom and insert the bottom tab into nose pad.
  6. Replacing Oakley Flak 2 Lens and Rubber Kits: étape 6, image 1 de 3 Replacing Oakley Flak 2 Lens and Rubber Kits: étape 6, image 2 de 3 Replacing Oakley Flak 2 Lens and Rubber Kits: étape 6, image 3 de 3
    • Insert the lens from the outer top corner.
    • Push the bottom corner of the lens closest to the frame's bridge up. An auditable pop will indicate the lens is inserted.
    • Repeat these steps for the other side.
  7. Replacing Oakley Flak 2 Lens and Rubber Kits: étape 7, image 1 de 2 Replacing Oakley Flak 2 Lens and Rubber Kits: étape 7, image 2 de 2
    Microfiber Cleaning Cloths
    $3.99
    J'achète
This guide can allow you to mix and match various rubber kits, and lens to create your own Oakley Flak 2 sunglasses.
2 autres ont terminé cette réparation.
Peter Tran
Membre depuis le 07/02/21
193 Réputation
1 tutoriel rédigé
Équipe
York University, Team S2-G27, Melo-Thaiss Summer 2021 Membre de l'équipe York University, Team S2-G27, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S2G27
1 membre
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 19
30 derniers jours : 87
Total : 2,001
