Aller au contenu principal
Replacing Strings on a Mandolin
Ce dont vous avez besoin
  1. Replacing Strings on a Mandolin, Mandolin Strings: étape 1, image 1 de 1
    • Place the mandolin on a firm, level surface with adequate lighting.
  2. Replacing Strings on a Mandolin: étape 2, image 1 de 1
    • Loosen the tuning nob.
    • Carefully remove the top end of string from the tuner in the mandolin head.
  3. Replacing Strings on a Mandolin: étape 3, image 1 de 1
    • Unhook the old string from the tail of the mandolin.
    • Remove the string from the bottom.
  4. Replacing Strings on a Mandolin: étape 4, image 1 de 1
    • Select a new string, and then insert the bottom end of it through the bridge at the tail.
  5. Replacing Strings on a Mandolin: étape 5, image 1 de 1
    • Secure the string to the tail by looping it over the hook.
  6. Replacing Strings on a Mandolin: étape 6, image 1 de 1
    • Pulling the string taut, bring its top end across the nut and into the tuning peg.
  7. Replacing Strings on a Mandolin: étape 7, image 1 de 1
    • Run the line through the tuning element at the head of the mandolin, as pictured. Be sure to pull the string away from the headstock.
  8. Replacing Strings on a Mandolin: étape 8, image 1 de 2 Replacing Strings on a Mandolin: étape 8, image 2 de 2
    • Pull the string down, towards the fretboard, and run the string underneath itself.
    • Pull the string tight so that it wraps around the tuning peg.
  9. Replacing Strings on a Mandolin: étape 9, image 1 de 1
    • Pinch the string over itself to create a knot.
  10. Replacing Strings on a Mandolin: étape 10, image 1 de 1
    • Tighten the tuning nob until the desired tension is reached.
  11. Replacing Strings on a Mandolin: étape 11, image 1 de 1
    • Clip off any excess string.
  12. Replacing Strings on a Mandolin: étape 12, image 1 de 1
    • Optional: Clip the electronic tuning device to the head of the mandolin; use the device to assist in fine-tuning your mandolin.
  13. Replacing Strings on a Mandolin: étape 13, image 1 de 1
    • Commence rocking on with your Gretsch New Yorker!
Ligne d'arrivée
3 autres ont terminé cette réparation.
Drew
Membre depuis le 03/18/15
125 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 15
Total : 7,485
