Aller au contenu principal
Replacing a Sprinkler Extension
Ce dont vous avez besoin
  1. Replacing a Sprinkler Extension, Sprinkler Extension: étape 1, image 1 de 1
    • Dig a one foot wide hole around the broken sprinkler extension down to the pipe fitting.
    • The pipe fitting is usually about one foot underground.
  2. Replacing a Sprinkler Extension: étape 2, image 1 de 1
    • Dig around the pipe fitting with a trowel to provide clear access.
  3. Replacing a Sprinkler Extension: étape 3, image 1 de 1
    • Clean the area around the fitting with water until the fitting is mostly free of dirt.
  4. Replacing a Sprinkler Extension: étape 4, image 1 de 2 Replacing a Sprinkler Extension: étape 4, image 2 de 2
    • Unscrew the sprinkler extension from the pipe fitting.
    • Once the extension is removed, water may come out of the open pipe fitting.
  5. Replacing a Sprinkler Extension: étape 5, image 1 de 1
    • Screw the new sprinkler extension in securely.
  6. Replacing a Sprinkler Extension: étape 6, image 1 de 2 Replacing a Sprinkler Extension: étape 6, image 2 de 2
    • Test the sprinkler to ensure that there are no leaks.
    • Refill the hole tightly.
If you have completed the steps successfully you should have a fully functioning sprinkler extension.
Abagayle Serreyn
Membre depuis le 09/11/15
111 Réputation
1 tutoriel rédigé
Équipe
Sam Houston State, Team 16-5, Nardone Fall 2015 Membre de l'équipe Sam Houston State, Team 16-5, Nardone Fall 2015
SHSU-NARDONE-F15S16G5
5 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 824
