Aller au contenu principal
Reupholstering a Couch Cushion
Ce dont vous avez besoin
  1. Reupholstering a Couch Cushion, Couch Upholstery: étape 1, image 1 de 3 Reupholstering a Couch Cushion, Couch Upholstery: étape 1, image 2 de 3 Reupholstering a Couch Cushion, Couch Upholstery: étape 1, image 3 de 3
    • Remove the cushion from the couch. This will easily insure you to get the proper measurements of the cushion.
  2. Reupholstering a Couch Cushion: étape 2, image 1 de 3 Reupholstering a Couch Cushion: étape 2, image 2 de 3 Reupholstering a Couch Cushion: étape 2, image 3 de 3
    • Using a tape measure, measure the height, width, and length the cushion.
  3. Reupholstering a Couch Cushion: étape 3, image 1 de 2 Reupholstering a Couch Cushion: étape 3, image 2 de 2
    • Replace the cushion with a new cushion.
    • In my case, I added a layer of new memory foam on the top and bottom of the existing cushion.
  4. Reupholstering a Couch Cushion: étape 4, image 1 de 1
    • Draw out the measurements on the new fabric.
    • Take the measurements you gathered from Step 2 and measure/draw it on the new fabric to accurately cut the the fabric.
  5. Reupholstering a Couch Cushion: étape 5, image 1 de 2 Reupholstering a Couch Cushion: étape 5, image 2 de 2
    • Cut new fabric along your designated measurement lines.
    • Iron the newly cut fabric to prevent any wrinkles. This will help make for a more smooth and easy process.
  6. Reupholstering a Couch Cushion: étape 6, image 1 de 1
    • Cover the cushion with the fabric
  7. Reupholstering a Couch Cushion: étape 7, image 1 de 2 Reupholstering a Couch Cushion: étape 7, image 2 de 2
    • Staple the fabric onto the cushion so it is secure enough that it will not come loose.
    • Once this step is completed, your cushion is all done and ready to be put back onto your couch!
    • If you would prefer: another way to secure the fabric around the cushion would be the sew it!
  8. Reupholstering a Couch Cushion: étape 8, image 1 de 1
    • Final product!
To reupholster your cushion, follow these instructions:
1. Remove the cushion(s) from the couch.
This will easily insure you to get the proper measurements of the cushion(s).
2. Using a tape measure, measure the height, width, and length of the cushion(s).
3. Replace the cushion with new cushion.
*In my case, I added a layer of new memory foam to the top and bottom of the existing cushion.
4. Draw out the measurements on the new fabric.
5. Cut and iron the new fabric to prevent any wrinkles. *This will help make for a more smooth and easy process.
6. Cover the cushion with the fabric
7. Staple the fabric onto the cushion so it is secure enough that it won’t come loose.
Tiffany St.Lifer
Membre depuis le 01/21/20
187 Réputation
1 tutoriel rédigé
Équipe
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020 Membre de l'équipe USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020
USFSM-STEWART-S20S1G1
23 membres
27 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 34
30 derniers jours : 121
Total : 4,039
