Aller au contenu principal
Samsung Galaxy TabPro S Rear Facing Camera Replacement
Ce dont vous avez besoin
  1. Samsung Galaxy TabPro S Rear Facing Camera Replacement, Rear Facing Camera: étape 1, image 1 de 1
    • Place the device face down on a flat work surface.
  2. Samsung Galaxy TabPro S Rear Facing Camera Replacement: étape 2, image 1 de 2 Samsung Galaxy TabPro S Rear Facing Camera Replacement: étape 2, image 2 de 2
    • Heat the iOpener in the microwave for 30 seconds. Then place it on each side for 20 seconds in order to loosen the adhesive sealing on the device.
  3. Samsung Galaxy TabPro S Rear Facing Camera Replacement: étape 3, image 1 de 3 Samsung Galaxy TabPro S Rear Facing Camera Replacement: étape 3, image 2 de 3 Samsung Galaxy TabPro S Rear Facing Camera Replacement: étape 3, image 3 de 3
    • Using the plastic spudger, open up the back of the device.
  4. Samsung Galaxy TabPro S Rear Facing Camera Replacement: étape 4, image 1 de 1
    • Locate the camera and its corresponding connecting port.
  5. Samsung Galaxy TabPro S Rear Facing Camera Replacement: étape 5, image 1 de 3 Samsung Galaxy TabPro S Rear Facing Camera Replacement: étape 5, image 2 de 3 Samsung Galaxy TabPro S Rear Facing Camera Replacement: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Using tweezers carefully peel off the sticker.
  6. Samsung Galaxy TabPro S Rear Facing Camera Replacement: étape 6, image 1 de 2 Samsung Galaxy TabPro S Rear Facing Camera Replacement: étape 6, image 2 de 2
    • Using the black nylon spudger, flip the top half of the connecting port downward until you hear a click.
  7. Samsung Galaxy TabPro S Rear Facing Camera Replacement: étape 7, image 1 de 1
    • Proceed to lift up the camera out of its resting position.
  8. Samsung Galaxy TabPro S Rear Facing Camera Replacement: étape 8, image 1 de 2 Samsung Galaxy TabPro S Rear Facing Camera Replacement: étape 8, image 2 de 2
    • Simply pull the camera parallel to the device out of its connecting port.
2 autres ont terminé cette réparation.
Jyotsna Gone
Membre depuis le 02/20/17
515 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 1-2, Sullivan Spring 2017 Membre de l'équipe USF Tampa, Team 1-2, Sullivan Spring 2017
USFT-SULLIVAN-S17S1G2
4 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 1,547
