Aller au contenu principal
Sony DualSense Controller Trigger Assembly Replacement
Ce dont vous avez besoin
  1. Sony DualSense Controller Trigger Assembly Replacement, Unclip the right end of the middle trim: étape 1, image 1 de 2 Sony DualSense Controller Trigger Assembly Replacement, Unclip the right end of the middle trim: étape 1, image 2 de 2
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. Sony DualSense Controller Trigger Assembly Replacement, Unclip the lower-right edge of the middle trim: étape 2, image 1 de 3 Sony DualSense Controller Trigger Assembly Replacement, Unclip the lower-right edge of the middle trim: étape 2, image 2 de 3 Sony DualSense Controller Trigger Assembly Replacement, Unclip the lower-right edge of the middle trim: étape 2, image 3 de 3
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. Sony DualSense Controller Trigger Assembly Replacement, Unclip the left end of the middle trim: étape 3, image 1 de 2 Sony DualSense Controller Trigger Assembly Replacement, Unclip the left end of the middle trim: étape 3, image 2 de 2
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. Sony DualSense Controller Trigger Assembly Replacement, Unclip the lower-left edge of the middle trim: étape 4, image 1 de 3 Sony DualSense Controller Trigger Assembly Replacement, Unclip the lower-left edge of the middle trim: étape 4, image 2 de 3 Sony DualSense Controller Trigger Assembly Replacement, Unclip the lower-left edge of the middle trim: étape 4, image 3 de 3
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. Sony DualSense Controller Trigger Assembly Replacement, Remove the middle trim: étape 5, image 1 de 3 Sony DualSense Controller Trigger Assembly Replacement, Remove the middle trim: étape 5, image 2 de 3 Sony DualSense Controller Trigger Assembly Replacement, Remove the middle trim: étape 5, image 3 de 3
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
  6. Sony DualSense Controller Trigger Assembly Replacement, Remove the L1 button: étape 6, image 1 de 3 Sony DualSense Controller Trigger Assembly Replacement, Remove the L1 button: étape 6, image 2 de 3 Sony DualSense Controller Trigger Assembly Replacement, Remove the L1 button: étape 6, image 3 de 3
    • Insert the flat end of a spudger into the gap above the L1 button.
    • Cover the button with your thumb to prevent it from ejecting across the room.
    • Pry upward to remove the L1 button.
  7. Sony DualSense Controller Trigger Assembly Replacement, Remove the R1 button: étape 7, image 1 de 3 Sony DualSense Controller Trigger Assembly Replacement, Remove the R1 button: étape 7, image 2 de 3 Sony DualSense Controller Trigger Assembly Replacement, Remove the R1 button: étape 7, image 3 de 3
    • Insert the flat end of a spudger into the gap above the R1 button.
    • Pry upward to remove the R1 button.
  8. Sony DualSense Controller Trigger Assembly Replacement, Remove the rear case: étape 8, image 1 de 2 Sony DualSense Controller Trigger Assembly Replacement, Remove the rear case: étape 8, image 2 de 2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
  9. Sony DualSense Controller Trigger Assembly Replacement: étape 9, image 1 de 2 Sony DualSense Controller Trigger Assembly Replacement: étape 9, image 2 de 2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
  10. Sony DualSense Controller Trigger Assembly Replacement: étape 10, image 1 de 3 Sony DualSense Controller Trigger Assembly Replacement: étape 10, image 2 de 3 Sony DualSense Controller Trigger Assembly Replacement: étape 10, image 3 de 3
    • Use the pointed edge of a spudger to unclip the two clips on either side of the headset jack.
  11. Sony DualSense Controller Trigger Assembly Replacement: étape 11, image 1 de 2 Sony DualSense Controller Trigger Assembly Replacement: étape 11, image 2 de 2
    • Remove the rear case.
    • On some revisions, the rear case is held with two more clips next to the previously removed bumpers. If the rear case doesn't open without force, check for those clips.
  12. Sony DualSense Controller Trigger Assembly Replacement, Disconnect the battery: étape 12, image 1 de 2 Sony DualSense Controller Trigger Assembly Replacement, Disconnect the battery: étape 12, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
    • Grip the connector, not the wires, when disconnecting.
  13. Sony DualSense Controller Trigger Assembly Replacement, Remove the battery: étape 13, image 1 de 2 Sony DualSense Controller Trigger Assembly Replacement, Remove the battery: étape 13, image 2 de 2
    • Lift the battery straight out of the battery bracket.
  14. Sony DualSense Controller Trigger Assembly Replacement, Remove the lower microphone: étape 14, image 1 de 2 Sony DualSense Controller Trigger Assembly Replacement, Remove the lower microphone: étape 14, image 2 de 2
    J'achète
    • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
  15. Sony DualSense Controller Trigger Assembly Replacement, Remove the battery bracket: étape 15, image 1 de 2 Sony DualSense Controller Trigger Assembly Replacement, Remove the battery bracket: étape 15, image 2 de 2
    • Use a Phillips screwdriver to remove the 6.4 mm screw securing the battery bracket.
  16. Sony DualSense Controller Trigger Assembly Replacement: étape 16, image 1 de 2 Sony DualSense Controller Trigger Assembly Replacement: étape 16, image 2 de 2
    • Lift the battery bracket out of the motherboard.
  17. Sony DualSense Controller Trigger Assembly Replacement, Disconnect the right trigger assembly: étape 17, image 1 de 2 Sony DualSense Controller Trigger Assembly Replacement, Disconnect the right trigger assembly: étape 17, image 2 de 2
    • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
    • Do not completely remove the ribbon cable yet.
  18. Sony DualSense Controller Trigger Assembly Replacement: étape 18, image 1 de 2 Sony DualSense Controller Trigger Assembly Replacement: étape 18, image 2 de 2
    • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
    • Remove the ribbon cable.
  19. Sony DualSense Controller Trigger Assembly Replacement, Disconnect the left trigger assembly: étape 19, image 1 de 2 Sony DualSense Controller Trigger Assembly Replacement, Disconnect the left trigger assembly: étape 19, image 2 de 2
    • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
  20. Sony DualSense Controller Trigger Assembly Replacement: étape 20, image 1 de 2 Sony DualSense Controller Trigger Assembly Replacement: étape 20, image 2 de 2
    • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
  21. Sony DualSense Controller Trigger Assembly Replacement, Disconnect the upper microphone: étape 21, image 1 de 2 Sony DualSense Controller Trigger Assembly Replacement, Disconnect the upper microphone: étape 21, image 2 de 2
    • Use a pair of tweezers or your fingers to grip the upper microphone ribbon cable pull tab, and pull up to disconnect it from the motherboard.
  22. Sony DualSense Controller Trigger Assembly Replacement, Disconnect the touchpad: étape 22, image 1 de 2 Sony DualSense Controller Trigger Assembly Replacement, Disconnect the touchpad: étape 22, image 2 de 2
    • Use a pair of tweezers or your fingers to grip the touchpad ribbon cable pull tab, and pull it straight out of the motherboard connector.
  23. Sony DualSense Controller Trigger Assembly Replacement, Lift out the motherboard: étape 23, image 1 de 3 Sony DualSense Controller Trigger Assembly Replacement, Lift out the motherboard: étape 23, image 2 de 3 Sony DualSense Controller Trigger Assembly Replacement, Lift out the motherboard: étape 23, image 3 de 3
    • Carefully guide the joysticks through the front case and lift the motherboard out.
    • Do not completely remove the motherboard. There are four soldered wires tethering the motherboard to the vibrator motors.
  24. Sony DualSense Controller Trigger Assembly Replacement, Remove the light guide: étape 24, image 1 de 2 Sony DualSense Controller Trigger Assembly Replacement, Remove the light guide: étape 24, image 2 de 2
    • Use a Phillips screwdriver to remove the two 8.5 mm screws securing the light guide.
  25. Sony DualSense Controller Trigger Assembly Replacement: étape 25, image 1 de 2 Sony DualSense Controller Trigger Assembly Replacement: étape 25, image 2 de 2
    J'achète
    • Use a pair of tweezers or your fingers to remove the light guide bracket.
  26. Sony DualSense Controller Trigger Assembly Replacement: étape 26, image 1 de 2 Sony DualSense Controller Trigger Assembly Replacement: étape 26, image 2 de 2
    • Use a pair of tweezers or your fingers to remove the light guide.
  27. Sony DualSense Controller Trigger Assembly Replacement, Remove the speaker: étape 27, image 1 de 3 Sony DualSense Controller Trigger Assembly Replacement, Remove the speaker: étape 27, image 2 de 3 Sony DualSense Controller Trigger Assembly Replacement, Remove the speaker: étape 27, image 3 de 3
    J'achète
    • Use a pair of tweezers to remove the speaker from the midframe.
    • Be sure to reinstall the speaker in the correct orientation with the foam pad on the left side and the gold contact points on the right.
  28. Sony DualSense Controller Trigger Assembly Replacement, Remove the midframe: étape 28, image 1 de 2 Sony DualSense Controller Trigger Assembly Replacement, Remove the midframe: étape 28, image 2 de 2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the midframe to the front case.
  29. Sony DualSense Controller Trigger Assembly Replacement: étape 29, image 1 de 3 Sony DualSense Controller Trigger Assembly Replacement: étape 29, image 2 de 3 Sony DualSense Controller Trigger Assembly Replacement: étape 29, image 3 de 3
    • Carefully lift the midframe and motherboard up and out of the front case.
    • Be careful not to strain the vibrator motor wires.
    • During reassembly, feed the touchpad's ribbon cable back through its rectangular opening in the midframe.
  30. Sony DualSense Controller Trigger Assembly Replacement, Remove the trigger assemblies: étape 30, image 1 de 2 Sony DualSense Controller Trigger Assembly Replacement, Remove the trigger assemblies: étape 30, image 2 de 2
    • Flip over the midframe and motherboard.
    • Use a Phillips screwdriver to remove the four 6.4 mm screws securing the trigger assemblies to the midframe.
    • If only one trigger assembly needs to be replaced, only remove the screws for that one.
  31. Sony DualSense Controller Trigger Assembly Replacement: étape 31, image 1 de 3 Sony DualSense Controller Trigger Assembly Replacement: étape 31, image 2 de 3 Sony DualSense Controller Trigger Assembly Replacement: étape 31, image 3 de 3
    • Carefully flip the midframe and motherboard over.
    • The trigger assemblies are loose and may fall out.
    • Remove the trigger assemblies.
20 autres ont terminé cette réparation.
Sam Omiotek
Membre depuis le 02/25/19
73 429 Réputation
288 tutoriels rédigés
20 commentaires
So after I completed this my L1 stopped working how do I fix that? Lol the L2 R1 and R2 work fine
Chris Doyle - Réponse
i know this is pretty long after you posted but could you tell me where you found the spare part?
Christos -
Ali express has everything since after warranty sony won't even look at your machine. Even for profit. Usbc port on the controller has no strength and I've had 2 go and that was from gentle use when I only had one controller then the second one did it so I had to buy 2 at once.
Joey Strong -
How do I find these parts? I’ve looked online for ps5 trigger assemblies and I can’t find them.
Avonlea - Réponse
hello. did you find the trigger spare part assemblies? I am also looking for it but unfortunately couldn't find them yet.
Sezer Metin -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 52
7 derniers jours : 366
30 derniers jours : 1,755
Total : 41,358
