Aller au contenu principal
Tapwave T2907US Zodiac 2 Auxiliary Port Replacement
Ce dont vous avez besoin
  1. Tapwave T2907US Zodiac 2 Auxiliary Port Replacement, Back Cover: étape 1, image 1 de 1
    • Remove the four Torx T5 screws from the back panel.
  2. Tapwave T2907US Zodiac 2 Auxiliary Port Replacement: étape 2, image 1 de 1
    • Wedge a spudger in between the front and back panel.
    • Apply leverage downwards to the spudger in order to remove the back panel.
  3. Tapwave T2907US Zodiac 2 Auxiliary Port Replacement, Battery: étape 3, image 1 de 1
    • Slide the battery out from under the brown wire-tape.
    • Be careful of the wires still connected to the other end of the battery. Do not pull or damage may occur.
  4. Tapwave T2907US Zodiac 2 Auxiliary Port Replacement: étape 4, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Slowly pull the white plug from its receptor. Grasp its sides firmly with a pair of tweezers and gently wiggle from side to side.
  5. Tapwave T2907US Zodiac 2 Auxiliary Port Replacement, Motherboard: étape 5, image 1 de 1
    • Unscrew the 2 Philips #00 screws on each end of the motherboard.
  6. Tapwave T2907US Zodiac 2 Auxiliary Port Replacement: étape 6, image 1 de 1
    J'achète
    • Pull off the black memory card slot piece with tweezers.
  7. Tapwave T2907US Zodiac 2 Auxiliary Port Replacement: étape 7, image 1 de 1
    • Unscrew the 2 Philips #00 screws on each side of the charging port.
  8. Tapwave T2907US Zodiac 2 Auxiliary Port Replacement: étape 8, image 1 de 2 Tapwave T2907US Zodiac 2 Auxiliary Port Replacement: étape 8, image 2 de 2
    • Disconnect 2 brown wire-tape ends from each end of the motherboard. Gently pull straight out with tweezers.
  9. Tapwave T2907US Zodiac 2 Auxiliary Port Replacement: étape 9, image 1 de 1
    • Pull the motherboard and screen component diagonally up and left away from the auxiliary port entrance to remove.
    • Glue connecting the auxiliary port to the casing may make it difficult to remove. Gently apply force as needed.
  10. Tapwave T2907US Zodiac 2 Auxiliary Port Replacement: étape 10, image 1 de 1
    • Disconnect the 2 brown wire-tape ends from the left side of the battery slot on the motherboard using tweezers.
  11. Tapwave T2907US Zodiac 2 Auxiliary Port Replacement: étape 11, image 1 de 3 Tapwave T2907US Zodiac 2 Auxiliary Port Replacement: étape 11, image 2 de 3 Tapwave T2907US Zodiac 2 Auxiliary Port Replacement: étape 11, image 3 de 3
    • Disconnect the large brown wire-tape from the motherboard.
    • Peel the black tape back from the wire-tape using tweezers.
    • Lift the black, hinged, plastic lock with tweezers to release the wire-tape.
    • The screen and motherboard components can now be separated from each other.
  12. Tapwave T2907US Zodiac 2 Auxiliary Port Replacement, Auxiliary Port: étape 12, image 1 de 1
    Desoldering Pump
    $3.99
    J'achète
    • Remove the solder between the auxiliary port and the motherboard carefully with the desoldering pump.
    • Try to avoid contact between the solder sucker and other components surrounding the auxiliary port.
    • Do not get too close to the soldering tip to avoid burn when soldering the new auxiliary port.
    • If you need further aid in desoldering/soldering the auxiliary port follow this guide on soldering components of devices.
Irvin Camacho
Membre depuis le 01/26/12
13 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 10-33, Amido Winter 2012 Membre de l'équipe Cal Poly, Team 10-33, Amido Winter 2012
CPSU-AMIDO-W12S10G33
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 643
