Aller au contenu principal
UE BOOM 2 Micro-USB Port Replacement
Ce dont vous avez besoin
  1. UE BOOM 2 Micro-USB Port Replacement, Micro-USB Port: étape 1, image 1 de 2 UE BOOM 2 Micro-USB Port Replacement, Micro-USB Port: étape 1, image 2 de 2
    • First, remove the D-ring located on the bottom of the UE Boom 2, the opposite end of the power button.
    • Remove by twisting in a counter-clockwise motion.
  2. UE BOOM 2 Micro-USB Port Replacement: étape 2, image 1 de 2 UE BOOM 2 Micro-USB Port Replacement: étape 2, image 2 de 2
    • After the D-ring has been removed, the rubber port cover can be removed.
  3. UE BOOM 2 Micro-USB Port Replacement: étape 3, image 1 de 3 UE BOOM 2 Micro-USB Port Replacement: étape 3, image 2 de 3 UE BOOM 2 Micro-USB Port Replacement: étape 3, image 3 de 3
    • Remove the rubber stripping using a metal spudger.
    • Work around the edge of the rubber stripping slowly prying up the edge.
  4. UE BOOM 2 Micro-USB Port Replacement: étape 4, image 1 de 1
    • Continue removing the rubber stripping down the side.
  5. UE BOOM 2 Micro-USB Port Replacement: étape 5, image 1 de 3 UE BOOM 2 Micro-USB Port Replacement: étape 5, image 2 de 3 UE BOOM 2 Micro-USB Port Replacement: étape 5, image 3 de 3
    • On the bottom, unscrew the four 15mm Phillips Head #2 screws, using the Phillips head #2 bit (labeled PH2 in the Pro Tech Toolkit).
    • Pry up at the location marked, and remove the plastic end cap.
    • The white plastic section houses the USB micro B, and must be replaced as a whole.
7 autres ont terminé cette réparation.
Alex Bahm
Membre depuis le 01/18/18
2 232 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team S12-G5, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S12-G5, Banghart Winter 2018
CPSU-BANGHART-W18S12G5
2 membres
15 tutoriels rédigés
6 commentaires
Hi,
Do you know where to buy this part?
Thanks!
cpgoga - Réponse
Hello,
I am also looking to find where to order this part? I have searched on ebay / internet with no luck.
KM
Roock Canada - Réponse
i too am looking to find the replacement part
Liam Nicholls - Réponse
Found a place you can replace the USB connector if you can do a bit of soldering/unsoldering.
https://www.joesge.com/products/micro-us...
Roger Burke - Réponse
Anyone have the part number to convert it to a USB type c instead of A?
vdub_corrado - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 31
30 derniers jours : 150
Total : 8,547
